Best Way To Span 32', Unsupported - Drafting & CAD Forum - Contractor Talk
Old 11-12-2017, 09:53 PM   #1
Swabbie's Avatar
Trade: carpentry
Rewards Points: 30
Hi y'all. First time poster. Thank you in advance for any responses to this.
Customer wants a 30'x50' open-bay Lean-To style carport. Not enclosed. He wants 6x6 supports around the perimeter of the building only. Completely open inside. No supports in the interior. Vertical suports will be 6'x6'x15' on the low side and 6'x6'x20' on the high to achieve a 2/12 roof pitch (this is in order to match his existing garage roofline - which this new carport will butt up against.) See pics.
Since its not an enclosed structure I'm thinking pressure treated Glulam LVL beams to span the 32' is my only option. Could use some help knowing if
1) This true or if there are other ways to do it that would be better &/or more economical (Metal construction isn't an option).
2) What LVL size beams would I use to handle worst case scenario snow load
3) How many LVL beams would I need to properly support the 32'x52' roof (1' overhang around 30x50 foundation)?
I will be getting drawings, engineering stamp, permits on this but want to approach them with most of it solved already to minimize the engineering on their end.
WRT the attachments. I just did a quick concept sketch in google sketchup to see if I was in the right ballpark with the customer on what he wanted. It's in no way a finished product. I put in 2x12x30 Glulam LVL's at 12" OC as just a place holder till I know what actually should go there.
Thanks again.
Best way to span 32', unsupported-screen-shot-2017-11-11-11.11.11-am.png   Best way to span 32', unsupported-screen-shot-2017-11-11-11.12.04-am.png   Best way to span 32', unsupported-screen-shot-2017-11-11-11.19.38-am.png   Best way to span 32', unsupported-screen-shot-2017-11-11-11.20.49-am.png
Swabbie is offline
Old 11-12-2017, 10:10 PM   #2
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
Re: Best Way To Span 32', Unsupported
Hi, just about impossible to answer without knowing snowloads, windloads etc. But...
What you are proposing will not work.
1. 6x6 will be to small
2. Lvl are not the same as glulam
If you are trying to stay as close to your design. You will want to embed proper size posts a certain depth into ground using sonotube and fill with concrete. Post every 12.5’(again will have to be determined)
Glulam beam running parallel to long distance spanning posts. Prob end up being 6” wide 14” deep.(tbd)
Then some top hung trusses spanning the 30’. C/w 2x4 purlins and metal roof.
Post will need proper bracing as well.
Something like that
Few more things, I shouldn’t just say 6x6 will be to small but I think they would. For the front you will need a 25’ 6x6 or something like that. If trying to stay wood, glulam posts are prob a better choice, also you prob could sub glulam rafters instead of trusses but it will be getting expensive at this point. Not to be rude but this whole exercise is kinda pointless without knowing local codes and loadings
MeanWeen is offline
The Following User Says Thank You to MeanWeen For This Useful Post:
Swabbie (11-13-2017)
Old 11-12-2017, 10:17 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 4,666
Steel framing.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
The Following 4 Users Say Thank You to WarnerConstInc. For This Useful Post:
AustinDB (11-13-2017), greg24k (11-14-2017), Swabbie (11-13-2017), Walraven (11-13-2017)
Old 11-12-2017, 11:22 PM   #4
Dirtywhiteboy's Avatar
Rewards Points: 8,382
2X4s
Dirtywhiteboy is offline
Old 11-13-2017, 07:01 AM   #5
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,632
Mono truss, unless you need the ceiling sloped.
Home Designer Series Software
B.Johnson is offline
The Following User Says Thank You to B.Johnson For This Useful Post:
Old 11-13-2017, 08:05 AM   #6
Swabbie's Avatar
Trade: carpentry
Rewards Points: 30
deleted
Swabbie is offline
Old 11-13-2017, 08:06 AM   #7
Swabbie's Avatar
Trade: carpentry
Rewards Points: 30
He does want the ceiling sloped/vaulted.
Swabbie is offline
Old 11-13-2017, 08:07 AM   #8
Swabbie's Avatar
Trade: carpentry
Rewards Points: 30
Something like that
Good Point. Forgot to mention the location. Anne Arundel County, MD. Looks like 25psf for Snow Load and between 90 and 125 Vmph for Wind load depending on what Category this building would fall under (No idea).
Knowing this, what are your thoughts now?
Reference:
http://dhcd.maryland.gov/Codes/Docum...01,%202012.pdf
Swabbie is offline
Old 11-13-2017, 08:11 AM   #9
Swabbie's Avatar
Trade: carpentry
Rewards Points: 30
Originally Posted by WarnerConstInc. View Post
Steel framing.
No really an option only because I have never worked with it. For academics, what would you specify for supports and beams to make this work in steel? Whats a good source to buy such materials. Project is in Maryland.
Swabbie is offline
Old 11-13-2017, 09:48 AM   #10
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 602
Damn hoss.
I'm all for helping folk out on here, and those who know me, know I've done my fair share, but sometimes, when a newb comes here, has never posted anything, and then wants complete design help, from scratch, I don't know what to say.
I'll say this, if you, as the Contractor, need this much help right from the start, and can't find it on your own, you might want to pass on this job.
But, in an effort to help you, this is how you should go about finding the info:
If you want to look into steel, call some local supply houses, and/or fabricators. I live 3,000 miles from you, I'm not gonna research steel sources for you. Then, talk to them about span.
Look into trusses. Call your local truss outfit, and get a price on trusses to span that much. I'm currently doing one that spans 42 feet, no supports. It's just not that hard.
Call your lumber yard, and get a price and specs on Glulam, LVLs, built-up beams, solid-sawn lumber, whatever. Learn the differences between them. Your lumber yard or the interweb can help you.
I'm happy to help in any way I can, but if gotta design, plan, and price, the whole thing for ya, I'm gonna bid it, too. I'll sub it out to ya.
Delta
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
hdavis (11-13-2017), Swabbie (11-13-2017)
Old 11-13-2017, 10:01 AM   #11
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 1,682
Which is what any of us would do.
Oh c'mon. Cut the crap. "minimize the engineering" translates into "how can I save money?"
cya...
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
ScipioAfricanus (11-13-2017), Swabbie (11-13-2017)
Old 11-13-2017, 11:01 AM   #12
hdavis's Avatar
Rewards Points: 2,897
All you need is a general idea and measured concept drawing, and the engineer will do the rest. It doesn't save you much to work out the structural details.
I agree with a previous poster, with no bracing, you'll have to sink the posts.
hdavis is online now
SmallTownGuy (11-13-2017), Swabbie (11-13-2017)
Old 11-13-2017, 12:05 PM   #13
Swabbie's Avatar
Trade: carpentry
Rewards Points: 30
Another advantage to ballpark engineering this (aside from my guy charging me less if it's mostly worked out) is I can work up a ball park materials estimate for the customer to then see if I am in his ballpark budget THEN we will pay to have it actually engineered. Standard practice from where I stand. As others have said, its not that hard. Thanks to those who helped me see there are components to this that I hadn't thought of.
Swabbie is offline
Old 11-13-2017, 12:44 PM   #14
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,272
First, I think you have to get your terms in the right ballpark.
WTF is a Glulam LVL?
The "beams" as you call them are roof joists.
"Vertical suports", aside from the spelling, I will give you, except to say we generally refer to them as posts.
You will not save any money trying to do the engineer's work for him. It doesn't work that way.
Andy.
ScipioAfricanus is offline
The Following 3 Users Say Thank You to ScipioAfricanus For This Useful Post:
hdavis (11-13-2017), parkers5150 (11-24-2017), Seven-Delta-FortyOne (11-13-2017)
Old 11-13-2017, 01:21 PM   #15
Willin's Avatar
Trade: Retired
Rewards Points: 432
You really need to ask this customer where he or she got the idea for this structure. Can he or she tell you where something like this can be seen already built, in the area?
A quick check with Weyerhaeuser's free Forte application shows that their 210 series TJI joists might work at the 16" depth, and at a spacing of 32".
This solution was gotten using a snow load of 25 psf and wind load of 20, live load at 12 and dead at 10.
Willin is offline
The Following User Says Thank You to Willin For This Useful Post:
Old 11-13-2017, 02:05 PM   #16
hdavis's Avatar
Actually, this is, in fact, that hard. Sizing girders and engineered rafters can be done by the supplier, no big deal. The posts and footings if unbraced aren't, and connections can be tricky.
Unless you think your time monkeying around with this has no value, go to a steel structure manufacturer and have them quote fabbed materials for the whole project.
Old 11-13-2017, 03:25 PM   #17
Swabbie's Avatar
Trade: carpentry
Rewards Points: 30
Thank you for the input. I haven't found where they make these for exterior application though.
Swabbie is offline
Old 11-13-2017, 04:31 PM   #18
Willin's Avatar
Trade: Retired
Rewards Points: 432
Then go 14" LVL on 16" centers. But an LVL isn't really OK unless you can build so it will always be dry.
If your client wants a wood framed structure with the rafters all exposed, he or she really owes you some info. Where was this seen? In what universe does a 30' clearspan woodframed carport structure exist with 25 psf ground snow loads?
For this to get built and survive, it will need some structural design for the frame (not the roofdeck structure) so as to have all the proper moment resistance.
Good luck.
Willin is offline
Old 11-13-2017, 06:49 PM   #19
Talking Head
EthanB's Avatar
Rewards Points: 148
The customer needs to have this engineered, then give you the plans to bid. You're going about this backwards, probably in the hopes that it will help you get the job, but it is most likely going to get you in a bad situation. I have no problem saying "see an architect/engineer, and then come to me for pricing."
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
Old 11-13-2017, 08:26 PM   #20
CPMKW's Avatar
Trade: GC PM
Rewards Points: 248
Design Build Contract...
Customer pays you X. For that price you get an engineered drawing done and provide a quote to build from that.
This way you get paid to quote it, the drawing gets paid for, and the customer feels committed to you due to the idea of a sunk cost.
Sent from my SM-G930W8 using Tapatalk
CPMKW is offline
The Following User Says Thank You to CPMKW For This Useful Post:
Seven-Delta-FortyOne (11-14-2017)
Joist Span on Decks Rizz861 Framing 6 06-11-2015 03:57 PM
Need help on span dimension. 7CB7 General Discussion 7 05-20-2013 07:01 PM
Is this entry span too wide? Californiadecks Decks & Fencing 15 08-22-2012 10:56 PM
proper subfloor AustinDB Tiling 35 05-26-2012 01:16 PM
Floor Joist Span BuriedHammer Framing 16 12-30-2008 09:03 PM
