Trade: BeckMacer
AutoCAD To .pdf - Missing Information
We are a consulting engineering firm using AutoCAD 2008, we have recently noticed that on a number of .pdf files that some of our information is missing. Could this be because the .dwg doesn't fully regenerate before plotting? If this is the case, how do we stop it happening? If not, are there any other ideas on how to rectify this problem?
Structural Engineer
Trade: Mechanical, Structural
Re: AutoCAD To .pdf - Missing Information
Check the obvious - layers being on or off, plot styles, pen set ups, etc. Pull up the properties of the objects that aren't plotting, and see if it's in a layer that's shut off for printing. Also check the scale of the object, line weight, etc. I've never had a problem with elements not showing up, unless it was one of the obvious issues, either in PDF or on media. But I'm also an old-school crank when it comes to layers: I layer everything in model space, and never draw anything but the title block and frame in paper space.
I used to think so.......
I print to pdf all the time. Everything that is on the dwg in the model and paper space ends up in the pdf.
When you are in paper space...double click inside the viewport of the drawing you wish to print...then check the layers to see if they are all on (the ones you want) It seems that in paper space you can have layers off...that don't show up as off, until you double click in the viewport. And if you are zoomed in too close...to get out of the viewport...type mv [enter] and scroll zoom out until you can see a space outside of the viewport, then [esc] and then double click in a space outside of the viewport. |
could be many different things. Have you tried asking at AUGI?
| Snowboard missing | CristianoCT | General Discussion | 19 | 01-29-2009 10:09 AM |
| Anyone have information on "Pearlite" combined with mortar? | Aladdin Builders | Flooring | 7 | 01-17-2009 05:49 PM |
| Need Pacific Region Information | Muntzster | General Discussion | 3 | 11-11-2008 10:36 AM |
| Hello everybody - I'm a AutoCad Operater | nicolebobbin | Introductions | 3 | 09-19-2008 09:28 PM |
