AutoCad Arch. Desktop
Old 05-09-2008, 01:06 AM   #1
Alwaysconfusd11's Avatar
Does anyone use AutoCad Arch. Desktop, Ive been using Acad for years, but just started using the arch. and cant figure out how to build in 3d, everything just builds on the same plane.
Alwaysconfusd11 is online now
Old 07-14-2008, 07:30 PM   #2
JPC2's Avatar
Trade: Fine Homebuilding, Remodeling
Wink
Re: AutoCad Arch. Desktop
I work in AutoCAD ADT too. I'm learning the 3-D features and I think they are totally the way to go - but I'm just not there yet. So I mostly still draw in 2-D so I know it's right and I can complete the set.
What version do you have?
JPC2 is offline
Old 07-14-2008, 07:51 PM   #3
2006 and 2008
Old 07-16-2008, 08:45 PM   #4
KentWhitten's Avatar
Problem with your method is it leaves room for error. That's the reason behind using BIM software like Revit and ArchiCAD. ACA they don't quite consider a true BIM software, but it's close enough.
As far as using it, I don't know. I gave up long ago. If I remember correctly, you need to set up constructs for your levels.
Try out Revit and see if you like it. They give you a free download for 30 days or something. The theory behind it goes something like this: a client wants you to move a window or a wall on the floor plans you drew. Sounds simple, but you now have to redraw elevations, sections, floor plans, details, etc.
Revit, since you are building a computer model, will update all of these settings for you, without redrawing and without errors whatsoever. ACA will do this also, but I'm not versed in it anymore. Really a big program to learn through and through. Revit, you'll be up and running in a week or two, then fine tuning from there.
BTW, they don't call it ADT anymore, it's now ACA, not to sound picky.
Salmon Falls Cabinetry
KentWhitten is offline
Old 07-16-2008, 10:03 PM   #5
JPC2's Avatar
Thanks for the suggestion. I totally agree with the BIM. I started drawing with the computer in the early 90's in high end remodeling. I'm very detail oriented and I have always thought that drawing in 3-D would help visualize and solve so many issues. I do new homes now too and see the unbelievable sales potential of 3-D. My problem is I can't get past the learning curve to the point where I feel comfortable issuing a drawing to the field. Plus, I'm a freak about lineweights and hatch scales.
I use ADT 2004. Have you heard of ArchiCAD? My neighbor has it and he turns out some really nice stuff.
JPC2 is offline
Old 07-16-2008, 10:07 PM   #6
I really need to learn revit I guess.
Old 07-17-2008, 01:37 PM   #7
ArchiCAD and Revit are very similar to each other. Their UI looks almost identical.
You don't HAVE to learn Revit, just what you feel comfortable about. I use Revit and get great results, but there are things that Revit does that bug the holy **** out of me
Old 07-17-2008, 06:07 PM   #8
I have it, I am going to try it out on a project tonight...see where it gets me,
frame and sheetrock an arch ch0mpie Carpentry 30 12-08-2010 12:00 PM
Autocad or Autocad LT 3Corgis Drafting & CAD Forum 10 03-10-2008 02:55 AM
i need a perfect arch and i dont have the room newnoise Introductions 8 03-27-2007 08:56 PM
Arch fault breakers edirector Electrical 17 08-25-2006 03:27 PM
