Squirrels Eating Through Siding
Old 03-04-2012, 11:52 AM   #1
Dan_Watson's Avatar
Rewards Points: 2,460
Squirrels made a nest in the wall cavity last year. This year we replaced the louvered vent, installing chicken wire under it to deter the squirrels from going through the louvers. Instead they decided to remove the entire vent. Any recommendations on getting rid of them for next year? Will they nest somewhere else and not come back here?
Dan_Watson is offline
Old 03-04-2012, 11:55 AM   #2
carpentershane's Avatar
Rewards Points: 520
Re: Squirrels Eating Through Siding
A squirrel relocation program! A live trap and a bus ticket to FL
I did a roof repair a few years ago where squirrels had chewed through the comp roofing, tar paper, and osb to make a nest in the soffit. What a vile mess...
"Perfection is an unachievable goal, the illusion of perfection is the work of a true craftsman. " LoneFramer
carpentershane is offline
Old 03-04-2012, 12:35 PM   #3
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
first pic looks like Lone was working there
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
Dan_Watson (03-04-2012), jkfox624 (03-04-2012)
Old 03-04-2012, 12:44 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,068
Wow. A lawn chair and a .22 rifle?
Cut some trees down and make it difficult for them to get there. You might try one of those ultrasonic noisemakers to discourage them. That helped us out with flying squirrels.
Tinstaafl is online now
Old 03-04-2012, 12:46 PM   #5
Dan_Watson's Avatar
BB gun is already being used. They also ate through the wires at the transformer and took the power out twice.
Old 03-04-2012, 12:53 PM   #6
Trade: siding
Rewards Points: 4
i did a vinyl corner ''chew'' repair once,the homeowner called up when he got home from work p.o.ed that i didn't repair it...but i did,they ate another hole in the meantime
Old 03-04-2012, 12:55 PM   #7
Capra aegagrus
Tinstaafl's Avatar
You need lethal, not annoying. Probably not viable in your case, but living in the woods here, we always have 3-4 cats roaming at will. Squirrels find life a bit easier if they don't hang out too close to the house.
Old 03-04-2012, 12:56 PM   #8
Rewards Points: 520
Sounds like you need to make an example of a squirrel. Shoot one and tack it to the wall as a warning to the others of what will befall them if they keep on chewing...
Old 03-04-2012, 12:59 PM   #9
Dan_Watson's Avatar
This is in the woods. The last barn cat had to be put down, and the 2 replacements will be out in the spring.
The BB gun took care of 3 but they were not the culprits.
Old 03-04-2012, 01:00 PM   #10
Trade: siding
Rewards Points: 4
mid america has vent cats i believe
carpentershane (03-04-2012)
Old 03-04-2012, 01:04 PM   #11
Framer53's Avatar
Trade: Handyman
Rewards Points: 254
I have a trap that is set up when the squirrels become too many. over the last few years I have moved over 25 squirrels to my step sons grave site, approx 6 miles from my house.
Right now we seem to have only 2 or 3 around.
My wife likes to use rat poison, but don't get caught with that......
Framer53 is offline
Old 03-04-2012, 01:15 PM   #12
Tom M's Avatar
Rewards Points: 4,570
Sqirkles are very damaging and relentless they willeat anything and die trying.
I had some go through vents but I spray painted the chicken wire and formed it over the outside of the vent and used the ring of the mid america to hold it on. Didnt look bad from the ground and it stopped it.
Cant do anything about wires but tree limbs should be cut away from the house. They may make a scented spray that will help discourage them.
Tom M is online now
Old 03-04-2012, 01:18 PM   #13
Trade: siding
Rewards Points: 4
Sqirkles? you bergen county guys
Old 03-04-2012, 01:29 PM   #14
Tom M's Avatar
Sorry Tom I know some guys eat them in your area.
Tom M is online now
Old 03-04-2012, 01:58 PM   #15
Trade: siding
Rewards Points: 4
legs braised in butter and flambe'ed with cognac
Dan_Watson (03-04-2012), Tom M (03-04-2012)
Old 03-06-2012, 06:23 PM   #16
Pest Control Specialists
ecowisepest's Avatar
Trade: pest control
looks like you need to trap them and relocate them you should upgrade to 1/4'" galvanized hardwear cloth instead of the chicken wire.
ecowisepest is offline
Should I tear off old wood siding? YJT Windows, Siding and Doors 11 08-21-2011 04:07 PM
New Siding Question RandyB1986 Windows, Siding and Doors 4 04-22-2010 12:35 PM
Can someone identify this siding? CharlesD Windows, Siding and Doors 2 02-12-2010 12:24 PM
ABC Supply Co. Inc. Acquires Chesapeake Siding and Roofing Grumpy Roofing 0 03-03-2009 09:40 AM
siding an old house gtmstang Windows, Siding and Doors 14 12-20-2008 06:21 PM
