Carpenter Ants
Old 04-27-2007, 09:49 PM   #1
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
Carpenter Ants
I should have taken a picture or two, but I had this job yesterday to fix a shed door that was attached to the main house. When I looked at it, I told the Homeowner...You need more than a fix...The entire Header and both the king and jack stud were devoured! Nothing left but dust.
I thought the ants had moved on until demo or DUST REMOVAL But I found the buggers starting on the opposite Jack Stud. Pourd Amonia on them as I didn't have anything else.
Think that worked??
LNG24 is offline
Old 04-27-2007, 10:42 PM   #2
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Re: Carpenter Ants
I would hope so!
A few years ago I was doing a porch remodel that had a ton of them. After the first day I asked the HO to get a pest guy out to kill them. When I showed up after a few days they were all over the place. This went on 3 times, he hired someone to come out and the things never died. Finally the HO went to the supermarket and bought something that killed them while we watch.
I use to carry some nasty spray stuff on the truck that would kill them but the product caused rashes so I stay away from it now.
Another porch remodel had tons of them in the beams, they were all over me and my helper. At lunch we went to a local diner where they decided to crawl out of our sleeves and all over the counter---people were freaking out. We finished our meal and never ate there again (who would want to eat at a place with bugs!)
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 04-28-2007, 12:35 AM   #3
Ed the Roofer's Avatar
Trade: Roofing Contractor
Re: Carpenter Ants
I had a garage about eight years ago, that once we removed the aluminum fascia, you could see the entire colony and all of their tunnels.
It looked as if we set it up like one of those ant colony things sandwiched between two sides of plexiglass.
They were all scurrying around to move the larvae to safer hidden grounds. We keep ant powder in stock, because less intense colonies can be found quite often.
It sucks for the guy nailing down the new plywood over the powder though. The air shoots it all over the place.
Ed
Ed the Roofer is offline
Old 06-08-2007, 11:57 PM   #4
SuperiorBuilt's Avatar
Trade: Home Remodeler
Re: Carpenter Ants
I once worked with a GC on a rental property many years back. The Gc goes to pull the plywood soffit down. As he pulls on the plywood, a ton of carpenter ants covered him. This brings new meaning to ants in your pants
SuperiorBuilt is offline
Old 01-04-2009, 08:15 AM   #5
duckdown's Avatar
Trade: Home Theater
Re: Carpenter Ants
Anyone ever considered putting in walls before hanging rock, those ant traps they sell at Walmart?
duckdown is offline
Old 01-04-2009, 09:26 AM   #6
Burby's Avatar
Trade: Remodel / repairs / Certified Mold inspector, Remediator
Send a message via AIM to Burby
Re: Carpenter Ants
With Carpenter ants, once the moisture intrusion & decay problem are both repaired, the ants will go away & stay gone.
And yup them lil buggers do bite harder than those lil no seeums at the dune line on the beach when the sun first goes down or just just prior to rising..
Proud to help make a house your Home
Never judge another by one's own intelligence
Burby is offline
Old 01-04-2009, 10:37 AM   #7
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Re: Carpenter Ants
I removed a window for replacement, and I did get covered from the little suckers. I think it was over 500 to 600. I had to run inside and put tyvek over the hole so they could not enter the house.
Carpenter Ants-bugs.jpg   Carpenter Ants-bugs-2-.jpg   Carpenter Ants-bugs-3-.jpg
Snobnd is offline
Old 01-04-2009, 03:54 PM   #8
General Contracting
LNG24's Avatar
Re: Carpenter Ants
No, but I have sprayed the wood with Ant Poison before sealing it up. Did that when I was moving an In Wall AC unit. As soon as I opened the wall, they were running everywhere. I vacuumed them up then dumped the vacuum contents far from the site. I ended up tearing out 12 linear feet of wall until I didn't see anymore. We sprayed all the wood before sealing it back up just to be safe. They hired a Pest Control company afterwords.
FYI: AC unit was leaking into the wall. Good thing they wanted us to move it.
LNG24 is offline
Old 01-04-2009, 05:01 PM   #9
Handle It!
MALCO.New.York's Avatar
Re: Carpenter Ants
Heavily soap laden water works as well.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 01-14-2009, 08:26 PM   #10
envirocare's Avatar
Trade: Pest Control
Re: Carpenter Ants
Just by killing the worker ants will not resolve the situation. You need to find the nest to permanently get rid of the problem.
Karl the Bug Man
Columbus, Ohio
Bed bugs Columbus Ohio Pest Control
envirocare is offline
Old 05-13-2009, 10:40 PM   #11
Dutch1962's Avatar
Trade: Pest Control
Re: Carpenter Ants
Karl is right and Carpenter ants also have several sattelite colonies that may move back in after you've killed the few members of their family.
Dutch1962 is offline
Old 05-13-2009, 10:45 PM   #12
Dutch1962's Avatar
Trade: Pest Control
Re: Carpenter Ants
PS. Nice pics
Old 05-14-2009, 12:27 AM   #13
envirocare's Avatar
Trade: Pest Control
Re: Carpenter Ants
Thanks Dutch1962, have you ever heard of using salt? I heard salt will also kill them cause they take the salt back to the colony and die of thirst. Might need to try this as a experiment sometime.
Karl the Bug Man
Columbus, Ohio
Old 05-14-2009, 12:53 AM   #14
solar guy
naptown CR's Avatar
Trade: solar contracting
Re: Carpenter Ants
I rented a vacation house in Maine once right at the end of a long dry spell. Came back one night and there were literally thousands of them crawling around the floor. I figured that everything dried out enough that there wasn't enough moisture left in the wood and they were looking for a drink. I did save the liquor. ended up spraying raid along the entire perimeter to keep them from coming upstairs to the bedrooms and bothering us in bed that night. I called the owner who decided that it was not a big deal and wouldn't do anything about it. I ended up hosing the bejesus out of the siding and trim so they would go back into the walls. worked while we were there but probably not the right thing to do.
naptown CR is offline
Old 07-29-2009, 12:52 PM   #15
AmeliaP's Avatar
Trade: Masonry
Re: Carpenter Ants
I'm having a problem with this. After treating around the foundation they are actually worse......must be a nest in the walls. Basement is super clean of them. We've been renovating down there and I didn't see 1.
AmeliaP is offline
Old 07-29-2009, 05:24 PM   #16
Warren's Avatar
Trade: framing/remodeling
Re: Carpenter Ants
Pulled out an old sliding door once and the outside ply of the header was just dust. They didn't go through the plywood spacer though. When I first pulled off the wall sheathing, the ants started swarming out. I had my shop vac ready and started devouring them. Must have been a few thousand. At one point, they were coming out faster than I could suck them up. After about 5 minutes they were down to just a few scattered singles.
Warren is offline
Carpenter ants karma_carpentry Carpentry 8 08-21-2007 07:11 PM
Carpenter? stephan148 General Discussion 5 07-11-2007 07:15 AM
Carpenter tells HO to install floor first Frankawitz Flooring 12 03-02-2007 06:50 PM
Apprentice-level carpenter with big ambitions dantheman General Discussion 11 06-13-2006 03:59 PM
