XPS and thoroseal. . .
Hey guys first post here and I'm hoping to get some advice on moisture control. I own a small plumbing shop, and we do light remodeling here and there as well, mostly 2 or 3 piece bathrooms in basements. Part of our standard procedures have been to apply 2" XPS with Z furring around the perimeter of the basements that we've been working in, sealing the band joist with XPS and expanding spray foam to seal up the joints. Generally, after hanging drywall on the Z furring, the humidity and moisture levels inside the basement improve dramatically.
The question that I have has to do with a customer who's approached me about what should be a regular job. His foundation is built out of 8" CMU and has about 4 layers of old peeling latex paint on it. The humidity down there is awful, it hits you as soon as you walk in. There's no water pooling, but the amount of moisture seeping through the foundation has obviously made the paint peel and even rusted out the steel hardware on some built in cabinets in one corner.
Will XPS applied over the foundation effectively manage the humidity? Or should I strip the paint and use thoroseal before putting up the walls? The difference between is going to be a major factor in how I cost the job out, which is why I'm asking.
Thanks a lot,
Keith C.
