On Top Of An Attic Floor
Old 10-21-2010, 06:08 PM   #1
valleyman's Avatar
Trade: Kitchen and Bath remodeling
Rewards Points: 75
I have an older rental house that I'd like to ad a little attic insulation to. Most of the attic is covered with plywood. Would it be effective for me to roll fiberglass insulation over top of the plywood, or would I have to tear out the floor and go between the joists?
valleyman is offline
Old 10-21-2010, 08:19 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,053
Re: On Top Of An Attic Floor
As long as you're confident that there's no airflow beneath the plywood, there would only be a tiny loss in efficacy by putting the insulation on top, probably not enough to warrant the labor involved in tearing it up. The only issue I could see is that you are potentially dealing with two vapor barriers, if there is one beneath the plywood. The plywood of course would form the second barrier.
In either case, I would use unfaced insulation.
Tinstaafl is online now
woodworkbykirk (10-21-2010)
Old 10-21-2010, 10:41 PM   #3
ASInsulation's Avatar
Trade: Insulation and Weatherization
Rewards Points: 220
unfaced insulation, and lay it out the opposite way of the studs as opposed to the same direction...just cuts out the seams...also, airseal whatever you possibly can, because if you add all the r-value with no airsealing, you aren't going to see much return
ASInsulation is offline
Old 10-22-2010, 09:23 PM   #4
valleyman's Avatar
Rewards Points: 75
Thanks, you've been very helpful.
Old 12-12-2010, 11:28 PM   #5
Dantheman723's Avatar
Trade: Mold
Why not dense pack with cellulose?. Unless the attic has knob & tube wiring.
Dantheman723 is offline
Old 02-07-2011, 02:33 PM   #6
millshome's Avatar
Trade: Home energy retrofits
Installing insulation over the decking is okay. Loose-fill fiberglass is the best insulator for attic floors. Unlike batt insulation, loose-fill doesn't leave any gaps and forms a seamless blanket over the entire attic. Its also much less expensive per R (r-value) to install blown fiberglass. As far as other types of blown-in, consider that cellulose is recycled newspaper with fire-retardant chemical sprayed on it... these chemicals can corrode wiring over time. Hope this helps!
millshome is offline
insulating basement floor Bencouver General Discussion 9 01-30-2010 05:41 PM
20k sq ft concrete floor, needs blast, seal, repair, leveling and polyurea BLASTPRO Sandblasting 7 01-16-2010 07:53 PM
sub floor over radiant heat slab benvolio Decks & Fencing 6 12-17-2009 09:39 AM
Replacing Floor Joists/Sill Plate Section WilsonRMDL Framing 3 12-15-2009 08:52 AM
Floor fill won't adhere to old concrete floor: help?? shaane Flooring 4 12-29-2008 10:21 PM
