Spray Foam Question
Old 05-21-2008, 11:43 PM   #1
NCDeere's Avatar
Trade: Electrical
Question
Spray Foam Question
Howdy. I have been lurking on this site for quite a while and really like it.
I have a question regarding spray foam insulation. I know that it can be 2-3 times more costly and that over time you will recoup your money through energy savings, but when I see it going in on TV, I keep having one question. If you ever need to modify your wiring or plumbing in a foam wall, it seems to me that you are out of luck and will have to destroy the insulation to get to it. I mean heaven forbid that you would have to do something like that but you never know.
So, how would I address repairs in a spray foam wall. Or am I worried about nothing?
Any other info you have that could push me in one direction or the other on using spray foam would be appreciated.
Thanks for your help.
Bryan
Iron Station, NC
NCDeere is offline
Old 05-22-2008, 12:59 AM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Spray Foam Question
If you needed to modify something, do so and replace the foam, small jobs have spray cans available, medium have Pak Kits available and larger ones, bring the spray foam guy back in
Chris
Chris Johnson is online now
Old 05-22-2008, 04:31 AM   #3
genecarp's Avatar
you could also modify the affected area with fibreglass insulation.
genecarp is offline
Old 10-11-2009, 04:22 PM   #4
JohnS's Avatar
Trade: Spray Foam Insulation
The worry about having to modify is a legit one but as was said earlier, the use of small kits and cans can make filling in and repair work very quick and easy. When changes have to be made the kits and cans can be done by most anyone as long as proper safety ventillation is obtained during the work.
JohnS is offline
Old 10-11-2009, 06:15 PM   #5
parts's Avatar
Trade: Insulation contractor
What happens if you need to replace the roofing sheathing were it has been sprayed? Also repair after a fire? The only way I can see getting out is with an adze
parts is offline
Old 12-07-2009, 03:56 PM   #6
Industrial and Commercial
rc-construction's Avatar
Trade: Roofing
A $150 froth pak.
rc-construction is offline
Old 12-07-2009, 04:16 PM   #7
wannabe
WNYcarpenter's Avatar
Trade: carpentry
it takes less space to get the required R value in spray foam than fiberglass. The stud bays aren't filled to the full width if the wall framing is 2x6, or 2x12 for the roof.
Wires are generally still accessible after insulation....ask the GC how many inches are being sprayed then you'll know the depth to run your wires.
We've started using foam a lot more recently...we do it in 2 shots.
1" after the house is weathered in to seal it up and to start drying out the lumber then finish after the rough ins before DW.
WNYcarpenter is offline
Old 12-12-2009, 11:21 PM   #8
dlarrivee's Avatar
Trade: Foam/FP/FS/etc.
What on earth are you talking about "depth to run your wires" it's not like you can run wires right near the interior face of a stud and pass any electrical inspection anywhere...
dlarrivee is offline
Old 12-12-2009, 11:34 PM   #9
katoman's Avatar
Trade: carpenter
Contrary to what the foam and shingle manufactures will claim, DO NOT foam against your roof sheathing unless you want to replace your shingles in a year.
Install baffles all the way from soffit to ridge if it's a cathedral ceiling. I worked for a new home builder who made this mistake on the first few with cathedral ceilings and the shingles failed in a year.
After we began installing baffles we had no further problems.
katoman is offline
Old 12-12-2009, 11:41 PM   #10
Sean
SLSTech's Avatar
Well I am sorry to hear you had problems but I doubt it was the foam - I can & I am sure many other members here can snap pictures of houses that have not had any issues like your describing.
The main problem with many of these installations is they do not understand how to tie everything together &/or they use the wrong materials.
SLSTech is offline
Old 01-22-2010, 10:32 AM   #11
zab's Avatar
Trade: Energy Renovation / Masonry
conduit
zab is offline
Old 01-22-2010, 11:06 AM   #12
tcleve4911's Avatar
Trade: Remodeling contractor
Originally Posted by zab View Post
conduit
Nobody's gonna run conduit.....geez
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 01-22-2010, 11:19 AM   #13
zab's Avatar
i should have specified flexible conduit. its a bit overkill for resi applications, but in my opinion completely worth it.
zab is offline
Old 01-22-2010, 11:37 AM   #14
tcleve4911's Avatar
Cost?
Back in Maine
Dubbin' Around
Old 01-22-2010, 11:54 AM   #15
smeagol's Avatar
Trade: new construction and remodeling
We tore off a church that had osb on top of rigid foam(5 Years OLD) Most spray foam companies we've dealt with net and dense pack the parralel chord vaults and still run chutes full length. Thats with trusses though and with stick frame i'd guess you need foam for the r-value.
smeagol is offline
Old 01-22-2010, 12:05 PM   #16
Tom Struble's Avatar
Trade: siding
when you run chutes full length in a rafter bay,how does that remove any heat and moisture from that bay?Or do we just assume that with dense pack or foam there won't be any moisture migration?Cooler directly under the sheathing is better for shingles I'm sure but don't most shingle man. say its OK to use them on a ''hot''roof?
this is just a question that's been in my head,seems the more i read building science stuff the less I'm sure of about anything
Tom Struble is offline
oldfrt (01-22-2010)
Old 01-22-2010, 12:15 PM   #17
tcleve4911's Avatar
I agree, Tom.
Every time I get my new issue from Finehomebuilding, or JLC, or This Old Shack and then going on line, I continually get mixed messages about ventilation, insulation, wraps and plastics and radon and CO and geez it goes on & on.
We should just live like our ancestors did in a drafty, stick house with no insulation & dirt floors.
But then we wouldn't have a great forum like this would we?
Back in Maine
Dubbin' Around
The Following User Says Thank You to tcleve4911 For This Useful Post:
Tom Struble (01-22-2010)
spray foam? jcovey Construction 8 02-27-2010 09:19 PM
Starting a spray foam business ldshadle Insulation 9 12-20-2009 06:30 PM
Spray foam insulation Mike Finley Insulation 17 10-11-2009 03:53 PM
Spray foam insulation? tgeb Insulation 5 12-16-2007 11:11 PM
Spray foam on roof of kneewall space? Wideawake Insulation 4 08-06-2007 07:14 AM
