Spray Foam Insulation?
Old 11-21-2006, 07:59 PM   #1
tgeb's Avatar
I have a job we are looking at that will require insulating a concrete ceiling in an underground utility room.
It was designed to have hat channel and 1" foam then sheet rock. We talked it over with the prime contractor and they have agreed to spray foam...IF it is fire rated not to produce toxic fumes.
Does anyone know about this stuff and where I would find specs on the flammability and toxicity.
And obviously we are looking for a contractor to do the install as well.
www.gebcon.com
tgeb is offline
Old 11-28-2006, 01:54 PM   #2
dlarrivee's Avatar
Trade: Foam/FP/FS/etc.
Re: Spray Foam Insulation?
Icynene is probably the safest spray foam, the polyurethane ones burn very easily and will produce fumes...
dlarrivee is offline
Old 11-28-2006, 06:43 PM   #3
tgeb's Avatar
Thanks! I will check into that.
I think I have found a local company that deals with Icynene and plan on giving them a call tomorrow. With any luck they can "hook me up".
www.gebcon.com
tgeb is offline
Old 02-07-2007, 09:20 PM   #4
Charles Bagley's Avatar
Trade: Landscaping
Any Texas foam contractors in the house, please contact me.
Charles Bagley is offline
Old 12-04-2007, 09:12 PM   #5
G-Rott's Avatar
Trade: builder
Check out Sealection500.com Demilac is produced in Texas
G-Rott is offline
Old 12-16-2007, 11:11 PM   #6
KesslerDweller's Avatar
Trade: Residential Construction
Charles - try Garland Insulating.
KesslerDweller is offline
spray foam? jcovey Construction 8 02-27-2010 09:19 PM
foam insulation daneosporin Masonry 1 08-09-2007 03:35 PM
opinions on spray foam insulation sprayfoamguy General Discussion 37 08-12-2006 12:16 PM
fastening wire + wrap to foam insulation mas Construction 0 07-07-2006 10:39 PM
Spray foam insulation DRIFT-O-MATIC Construction 17 03-12-2005 11:21 PM
