Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Insulation
Old 01-25-2009, 06:02 PM   #1
MEL
Trade: Roofing
Roofer has questions
I am a roof replacement contractor and I am planning on offering blown in insulation as an add-on to roofing jobs.
I have a few questions and I wondering if you can help me.
  • 1.What do you use to hold insulation away from recessed lights?
  • 2.What do you use to hold insulation away from flue pipes and chimneys?
  • 3.What do you use to hold insulation back around the attic access opening?
  • 4.Do you install baffles to allow airflow from the soffit between each truss?
Thanks for your help
MEL
MEL is offline   Reply With Quote
Old 01-26-2009, 06:11 AM   #2
joasis's Avatar
Most new construction can lights are IC, or insulation compatible. The rest of what you are asking is done with blocking. Some builders use OSB, ply, or whatever to create dams if needed. If the flue is up to code, it needs nothing anyway. There are soffit blocks and baffles to keep it out of vents. An insulation supply company can set you up with this stuff.
So what kind of blower are you planning on buying? My son does this as his sideline business, and runs an Insulmaxx 4000.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
405 314 5802
joasis is offline   Reply With Quote
Old 01-26-2009, 06:34 AM   #3
Trade: roofing
When i bought my house i did the roof & blown in at the same time which was easier since i had a lot of decking off. I would suggest some kind of small homeade wooden rake/sweeper to be able to move the stuff around since it's hard to crawl around at the eaves.
Just letting you know that you'll look like frosty the snowman when your done & may feel like you need one of these...
Just a Roofer is offline   Reply With Quote
Old 02-04-2009, 05:36 PM   #4
stop botherin' me!
Grumpy's Avatar
Trade: Roofing Siding Gutters Windows
Cardboard is fine to use for blicking, although I prefer something more substantial around the roof hatch to keeo the insulation from falling inside when you open the hatch.
Since I am not a new construciton guy I have to assume the builder went cheap when he put in his canned lights, therefore I always block them. Better be safe than sorry.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline   Reply With Quote
Old 02-27-2009, 06:21 PM   #5
Trade: contractor
what about his venting question?
jjaayy is offline   Reply With Quote
Old 03-02-2009, 02:26 PM   #6
parts's Avatar
Trade: Insulation contractor
How about hiring someone who does it already or maybe I should start doing roofs
parts is offline   Reply With Quote
Old 03-04-2009, 04:23 PM   #7
Trade: former insulation supperviser, wallspray trainner
insul sheild is what you an use on can lights and b-vents. ic rated cans are fine to cover but insulation will create so much heat the lights will burn out quicker and make them flicker.
the baffle question is a loaded question depeands on if it contuinse soffit or if you have to vent for ice damming or how meany vents. Codes will better explain the baffle and vent situation.
Denny Lyman is offline   Reply With Quote
Old 03-07-2009, 11:25 AM   #8
MEL
Trade: Roofing
You guys are in for some competition from roofers so get used to it.
MEL
Old 03-07-2009, 12:22 PM   #9
parts's Avatar
That doesn't mean I have to make it easy. If you make money doing the roof why step on toes of those who make money doing the insulation. When I worked for a big company they did it all none of it well. Stick with what you are good at and everyone will profit.
Old 03-08-2009, 04:33 PM   #10
MEL
Trade: Roofing
You should learn roofing
A good roofing contractor should be doing an attic inspection and improving the ventilation.
Since we are already on the job it would be easy to blow in some insulation.
It’s a great way to increase the profit from a job.
You can get all kinds of information about roofing from this site or its affiliate RoofingTalk.com.
Be my guest to learn as much about roofing as you want. You and I will never be competitors and even if we were there are already thousands of competitors out there, so what difference does it make.
Why not expand your horizon?
You’re not going to be able to stop roofers from taking market share away from insulation guys. We are better sales people and we add value by making sure the attic is properly ventilated and the insulation is properly installed.
From what I have seen most insulation contractors are hacks. The leave the home in worse condition than what is was before they touched it.
MEL
Old 03-13-2009, 06:26 AM   #11
parts's Avatar
That's because most people think there is nothing to it hire a bunch of laborers and pay them next to nothing. There is a lot more to it than most people think especially doing right
Old 03-21-2009, 11:35 PM   #12
Trade: insulation and roofing
hi to all steve all. All- Star insulation and roofing inc st louis mo
fitzsm is offline   Reply With Quote
Old 04-03-2009, 02:30 AM   #13
Do not listen to that guy
do not use cardboard or wood around lighting... they sell styrofoam or like can sheilds.... the duct should only be done with metal....even b vent pipe...
2x6 or osb plywood for the attic scuttle......
consolidatedbui is offline   Reply With Quote
Who's a Roofer? Slyfox Roofing 57 05-07-2008 04:00 PM
Pricing questions Brian Painting & Finish Work 3 10-13-2007 08:38 AM
Roofer vs. Roofer (Just a long winded hypothetical) Thunder1 Roofing 7 12-01-2005 10:22 PM
