Rigid Foam Cutters
Old 10-13-2008, 03:39 PM   #1
manulind's Avatar
Trade: Insulation
Rigid Foam Cutters
I am working more and more with rigid foam insulation. Does anyone have more information and/or experience with Riema USA foam cutters?
manulind is offline
Old 10-20-2008, 07:45 PM   #2
JoeBudden's Avatar
Trade: EIFS
Re: Rigid Foam Cutters
IMO it's limited. What are you planning to use this for?
I'll PM a link to the cheapest foam cutting MACHINE I've found - and subsequently bought. Highly recommended.
Beautiful, durable, easy to install exterior architectural trim.
JoeBudden is offline
Old 10-20-2008, 07:46 PM   #3
JoeBudden's Avatar
Trade: EIFS
I guess the forum doesn't have a PM option.
Old 10-20-2008, 07:59 PM   #4
Sean
SLSTech's Avatar
I think you have to get past 15 posts before you can PM or post links - however, nothing prevents you from listing the tool & model number
SLSTech is offline
Old 11-04-2008, 10:02 PM   #5
Dan13's Avatar
Trade: Cabinetry
You might want to do a search under duct bd. cutters as duct bd. is basically the same material as foam bd. and with these cutters they allow you to make 45* cuts, lap joints althought there pretty pricey but if it makes your life easier they maybe worth the money.
Dan13 is offline
Spray foam question NCDeere Insulation 16 01-22-2010 12:15 PM
Fire retardant spray foam kdub1777 Electrical 8 10-12-2008 01:15 PM
Spray Foam Damage - HELP! crawfobc Insulation 4 07-04-2008 10:07 PM
R15 plus 1/2" rigid foam genecarp Insulation 6 03-31-2008 06:04 PM
Rigid Foam Insulation THP Construction 14 03-25-2005 03:13 PM
