Removing Old Insulation?
Old 04-25-2008, 11:09 PM   #1
missgrit22's Avatar
Trade: Insulation
Question
Hi, just found this site and I am greatful because I frequently run into situations where I could use advice. I have been insulating for myself for a few years from now, but today I had a first. I was asked if I could remove some old cellulose that was supposed to have gotten wet. Do yall know of the easiest way to do this, (short of buyin one of those vaccuums)? It is a large house, about 2000 square foot. They also want the sellulose to be replaced with blown fiberglass @ R-38. All of this was recommended by the power company. I know that R-38 is recommende for our area (Alabama). There is a young girl with asthma and the only reason that they want to install fiberglass is because they were told that the cellulose would bother her asthma. Is this true? I thought that is all settles and wouldn't be a bother on the ground floor in a few days, and if it were, it seems as if the fiberglass would be worse? . Thanks in advance!
missgrit22 is offline
Old 04-26-2008, 04:55 AM   #2
genecarp's Avatar
Rewards Points: 2,000
Re: Removing Old Insulation?
welcome to the site, there is no magic for removing insulation, as far as any type being a problem for a person with asthma, during the installation any type would be a problem, after insall is complete, if done properly, there should be no airborne contaminents.
genecarp is offline
Old 04-26-2008, 06:51 AM   #3
Joasis's Avatar
Rewards Points: 1,304
We don't hav a vacuum, but I thought up a cheaper way would be to get a dust collector, one of the small, single machine types...$125 or so, and use your 3 inch hoses...should work great. Unless the cellulose actually "feel" damp, or tests with a moisture meter to be damp, why pull it out now? If it is dry, it should be no problem...and the stuff we use is extremely mold resistant.
As above, it is ridiculous to blow fiberglass when cellulose is the much better product. My son insulated a lady's attic and simply set up the wet nozzle and "misted" the product...virtually no dust, which she was happy with. Worked fine.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 04-27-2008, 08:00 PM   #4
missgrit22's Avatar
Trade: Insulation
Thanks for the replies. What exactly are you referring to when you say dust collector? We have been thinking too and thought about using one or two large shop vacs? Might have to make a few reducers and such but it may work. I am going to make a few calls to see if a vac ia available to rent around here, but I highly doubt it.
That is what I was thinking as far as the insulation being an irritant, only during the process. These people had their mind made up before I got there, ya know. If I had known he wanted fiberglass blown in, I may have passed it up. It just makes no since to me. The only time that should be used is on a mobile home. But I'm just a small time operation in a small town and it would not be wise to turn down any job.
If you guys vcome with anything for a vac, please post. Also, what do you prefer to get you UP to catherdral ceilings? All of this new stuff is falling in my lap at once!
Old 04-27-2008, 10:49 PM   #5
InsulPro's Avatar
Trade: Insulation Installer/Building Contractor
Fiberglass blow-in is not that irritating, in fact my eyes burn, and my nose is
more plugged after blowing cellulose. I'm sure it depends on what machine you blow cellulose with, but even with the low dust formula I can not idle my machine low enough to not have to shut of the machine after five minuets of blowing to let the dust settle. As far as the removal, I have an insulation vaccuum, but I will not use it for cellulose removal because you don't know what is in that insulation. It could break the fins on your machine and those things are not cheap to replace, so I agree with Joasis on the use of the $125vacuum, and like he said, "if it's not wet, why take it out?"
InsulPro is offline
Old 04-28-2008, 07:09 AM   #6
Joasis's Avatar
Go to one of the cheap tool houses, like Harbor Freight, and they have small dust collectors....probably less then $100. You can use your hoses you already have.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Joasis is offline
Old 06-26-2009, 04:35 AM   #7
jojo123's Avatar
Trade: blackwater construction
I hate to tell you this, but I happen to be one of those people that it should not bother. Would you care to see my 6 er visits? What happens is the exposure takes several hours. Usually while I am sleeping & I wake up at 2am and cannot breathe. It is very scary. At this time I am trying remove all the insulation in the attic. I have cleaned over the master br.things have improved since I took off the side of the house and installed this huge fan. I am looking for a vacuum but have had no luck. I tried to modify a shop vac. but that did not work. The house is old(inhereted from my grandmother) the insulation has been wet in past & is clumped together. This will take me months to accomplish. I located a company close to huntsville al, that has the vacuum equipment but can't find their number/ If anyone in north alabama does this I could surely use their help. We build boat docks so this type remodeling is very new to us. Any advice would be useful thanks JoJo123
jojo123 is offline
Old 07-17-2009, 07:43 AM   #8
jojo123's Avatar
get one of those leaf blowers that will vacuum and mulch. i got mine at home depot. take one of those long dry vent, the tin foil covered ones and run it out side the house instead of trying to use the bag that comes with it. It will take you several days but it beats $3000 for one of the insulation remover vac. Mine cost about $70. Good luck. I had 6 ER visits before I discovered this. Aslo try to wear a mask and purchase a good fan to ventalate the area well.
jojo123 is offline
Old 07-17-2009, 11:43 AM   #9
JumboJack for president!
XanadooLTD's Avatar
Trade: Hilti walking billboard
spray foam the attic
XanadooLTD is offline
Old 11-29-2011, 07:24 PM   #10
1stchoiceinsul's Avatar
Trade: insulation
Originally Posted by missgrit22 View Post
hi, just found this site and i am greatful because i frequently run into situations where i could use advice. I have been insulating for myself for a few years from now, but today i had a first. I was asked if i could remove some old cellulose that was supposed to have gotten wet. Do yall know of the easiest way to do this, (short of buyin one of those vaccuums)? It is a large house, about 2000 square foot. They also want the sellulose to be replaced with blown fiberglass @ r-38. All of this was recommended by the power company. I know that r-38 is recommende for our area (alabama). There is a young girl with asthma and the only reason that they want to install fiberglass is because they were told that the cellulose would bother her asthma. Is this true? I thought that is all settles and wouldn't be a bother on the ground floor in a few days, and if it were, it seems as if the fiberglass would be worse? . Thanks in advance!
2563378441
1stchoiceinsul is offline
Old 11-29-2011, 07:27 PM   #11
Trade: insulation
We have an insulation vacuum please call us.2563378441.thumbsup:
THrown-in insulation: No soffit vents... Ted W Insulation 19 08-15-2009 11:35 AM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 07:57 PM
2000 sf of ceiling...how to remove insulation? carlspackler Remodeling 8 11-26-2006 10:01 AM
Interesting attic insulation findings IHI General Discussion 5 02-28-2006 01:22 PM
Removing stain from a french door or replace? Mike F Painting & Finish Work 6 03-22-2004 09:46 PM
