R15 Plus 1/2" Rigid Foam
i am building my own house, i wanted to experiment with additional insulation, i have 2 by 4 framing, this is a reno, 2 by 4 exist, or i would have gone 2 by 6, i installed R15 in the walls, then installed 1/2" rigid foam, foil facing in to room, i taped the joints, with foil tape, then installed 1/2" rock over that 1,3/4" screws, also after talking to some insulation guys, i scored the r15 paper. outside will be eifs, 1'' foam prior to stucco, any thoughts or feedback.thanks
Re: R15 Plus 1/2" Rigid Foam
Curious about the "R-15"?
I see R-11 and R-13 batts, who makes the R-15?
owens corning, r15 for 2by4 walls, most yards around new york carry it.
Builder/Remodeler
R-15 bats?
I'm curious as well... (I'm certainly not the grammar sheriff, but your post is a run-on mess...can you be a bit clearer?) What kind of windows are you using? Anything other than 1/2" inside (sheetrock) and 1/2" outside (sheathing), means you will likely need extension jambs when you go to trim the inside with casing, sill & apron. EDIT: Just found the R-15 on the OC site--I'm in the same area as Neolithic & can't say I've seen that offered in our area.
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here Last edited by ChrWright; 03-31-2008 at 08:11 AM. |
Cool!
Trade: Masonry consultant
Did they actually allow you to put a real Dryvit EFIS system over wood frame? - or is it just a sythetic stucco system?
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
| Foam Board vs. OSB | JimmyZimmier | Framing | 17 | 11-06-2010 05:54 PM |
| spray foam? | jcovey | Construction | 8 | 02-27-2010 09:19 PM |
| Rigid Tile Saw | orson | Ceramic & Stone Tile | 9 | 02-28-2008 08:26 AM |
| Isulating with Foam for Roofs? | FrankJr | Construction | 2 | 03-25-2006 10:05 PM |
| Rigid Foam Insulation | THP | Construction | 14 | 03-25-2005 03:13 PM |
