Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Insulation
Old 02-02-2009, 08:40 AM   #1
bighammer's Avatar
Trade: Lead Nail Bender....
Proper vents in Cathedral
I have been wondering what would be the best way to properly install my propervents and insulation in my 8/12 pitch cathedral roof. I have framed it with 2"x8" and have it sheathed,roofing materials applied and "low-omni" roll installed at ridge for my exhaust. I have some options, but wondering what other discussion could be made on this topic, as it can be very important for long term performance.
1) installing 1"x2" tight to sheathing on the underside of the roof deck continuous from plate to ridge and than installing masonite to the 1"x2" to make my proper vent (air chutes). Filling the rest of the cavity with fiberglass
2) installing spray foam in the joist spacing and not thinking twice about it.
3) installing 1"-2" bead board style foam board to the underneath side of the roof deck and than using fiberglass to fill the cavity.
Thoughts and discussion and very welcome. Thank you!!
bighammer is offline   Reply With Quote
Old 02-02-2009, 10:04 AM   #2
DILLIGAF
doubleaction's Avatar
Trade: Decorative Concrete, Remodeling, Decks
I would use a rigid foam insulation board cut to fit snugly between the rafter bays to create about a 2" channe for air flowl. then seal with cans of spray foam and put fiberglass on that.
Eric Swanson
http://www.carpenterology.tripod.com/Remodeling, Decks, ect.
Trinity Concrete LLC. Decorative concrete. Stamped concrete, vertical stamped concrete ( we are a Flex-c-Ment certified contractor) overlays, ect.
doubleaction is offline   Reply With Quote
Old 02-02-2009, 10:33 AM   #3
If you can get the R value up to 50 you can avoid ventilation all together. I am not sure you can pull that off with 2 X 8 Rafters. You maybe able to with foam insulation.
Another option a "cold roof" insulate the rafter bays with fiberglass. Install sleepers on top of the roof rafters and sheathing. Install sheathing on top of that and you have a ventilation channel.
I live in the north east and see problems with cathedral or vaulted ceiling all the time. If you insulate the bays and have your ventilation channel above the insulation you will get condensation it the ventilation bay.
My preference is to get the ceiling up to an R 50.
maceycon is offline   Reply With Quote
Old 02-02-2009, 10:43 AM   #4
bighammer's Avatar
than do you use a vapor barrier after installing the fiberglass? the rigid foam could trap moisture? the foam is than just friction fit into place?
Old 02-02-2009, 10:46 AM   #5
bighammer's Avatar
I have never heard that about the R50, however, if I install "sleepers" over my roof deck , how do I get that to ventilate, do I have to add additional vents from my soffits? Maybe I am not understanding...
Old 02-02-2009, 11:04 AM   #6
Trade: Home Remodeling
I'd go with spray foam.
KHouse75 is offline   Reply With Quote
Old 02-02-2009, 11:39 AM   #7
bighammer's Avatar
Have you ever done this, does the foam "breath"? I suppose close cell will not cause any condesation..no way for air to travel thru it? Would that not make the roof deck extremely hot in the summer, I was told at one time that code in this area required atleast 1" space between roof deck and insulation.
Old 02-02-2009, 12:16 PM   #8
Sean
SLSTech's Avatar
Closed cell spray foam - Demilic
The system works great, & you don't have to worry about ventilation
The problems with all the other systems, if you mess it up you can run into problems real quick
It is not cheap but in my book worth it. Here is one job I had done with the Demilic Soy Foam which was done by AIT Insulation out of Auburn
If money is an issue I would go with you 1st choice except for masonite I would go with what double action stated
SLSTech is online now   Reply With Quote
The Following User Says Thank You to SLSTech For This Useful Post:
bighammer (02-02-2009)
Old 02-02-2009, 12:21 PM   #9
tomstruble's Avatar
Trade: siding
http://www.hpanels.com/pages/pdfs/Li...ol-Vent-bw.pdf
check this out
tomstruble is online now   Reply With Quote
Old 02-02-2009, 06:02 PM   #10
That is the best solution!!!, but skip the 2" bay for ventilation.
Improperly installed roof vents. HWCostruction Roofing 13 01-31-2009 03:01 PM
Proper vents (air chutes) bighammer Insulation 3 01-08-2009 08:47 PM
Cathedral ceiling ridge cracks Tinstaafl Drywall 27 10-27-2008 11:59 PM
seal gable vents after ridge vent installed? tacoma5050 Roofing 26 01-18-2008 10:50 PM
Copper vents -vs- plastic/aluminum shopman Roofing 2 03-01-2006 08:51 AM
