Insulation Under A Metal Roof
Old 12-03-2008, 08:20 PM   #1
Kevin75
Guest
Kevin75's Avatar
Posts: n/a
I had a client ask the following and wasn't sure of the answer:
What is the best way to insulate between the ceiling joists under a standing seam metal roof?
It's a very old house with a flat roof. The joists are 2x6 or 2x8...I didn't measure them since I was on the roof outside when he asked the question. There is no attic space. He noted that the metal roof gets some condensation on the inside due to the temperature difference. He wants to insulate and then drywall underneath.
I appreciate any suggestions.
Thanks!
Old 12-03-2008, 08:21 PM   #2
joasis
Guest
joasis's Avatar
Posts: n/a
Re: Insulation Under A Metal Roof
Sprat foam would be best.
Old 12-04-2008, 03:14 PM   #3
Kevin75
Guest
Kevin75's Avatar
Posts: n/a
Is it tricky to use closed cell foam insulation kits? This is for a ceiling job.
Old 12-04-2008, 05:20 PM   #4
Morning Wood
Guest
Morning Wood's Avatar
Posts: n/a
Hire a insulation company that blows in closed cell spray foam. That will give you the most insualtion for such a small rafter. If there is enough head room then I would put 1-2" of rigid foam on the inside of the rafters to create a thermal break. They you can strap and blueboard.
Old 12-04-2008, 06:00 PM   #5
SLSTech
Guest
SLSTech's Avatar
Posts: n/a
You won't get the same results & the cost for the DIY kits equals what a pro charges
Valley flashing on a metal roof Quinn Roofing 0 11-07-2008 03:08 PM
Insulating Roof and To Vent Or Not To Vent Morning Wood Construction 3 11-03-2008 08:39 PM
Metal Roofing Aframe Roofing 4 03-26-2008 08:42 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
