Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Insulation
Old 10-10-2009, 07:19 PM   #1
AnthonyRichard's Avatar
Insulation questions
Hello, I recently purchased a 1951 one and a half story home in MN. It is currently totally gutted and I would like to insulate it myself. I need some help from experienced insulators. All the exterior framing is 2x4 including the roof. I need to achieve at least an r19. I have pretty much ruled out sprayed foam due to cost. What are my options as a do-it-yourselfer? Can I put batt insulation and than cover the entire surface with one inch rigid foam? Can I use 2 inch foam in-between the rafters and then cover the entire roof with one inch rigid foam? Any help at all would be appreciated. Thanks, Tony
-Tony
AnthonyRichard is offline   Reply With Quote
Old 10-11-2009, 05:24 PM   #2
parts's Avatar
Trade: Insulation contractor
Watch the price of the foam board it adds up fast and your labor is worth something. Doing it yourself also limits what you can do. Getting an R-19 min is a good idea but with 2x4 walls not an easy thing. Did you do a ResCheck to find out what you need or did the inspector tell you. Too much foam between the studs and sheetrock can cause headaches in it self
parts is offline   Reply With Quote
Old 10-18-2009, 08:06 AM   #3
Trade: Rennovation
If you have 2x4, you could use kraft faced R-13 or R-15 that is 3.5 thick inches. I'm currently doing a similar project. Lowes is doing a 'truckload event' which means if you buy $400 worth of in stock insulation, you get a $100 gift card (mail in rebate).
Rennovator is offline   Reply With Quote
Old 10-18-2009, 08:44 AM   #4
genecarp's Avatar
Welcome to CT, are you a proffesional contractor/carpenter, or are you a homeowner working on your own home, thanks.
genecarp is online now   Reply With Quote
Old 10-18-2009, 09:05 AM   #5
Originally Posted by AnthonyRichard View Post
Old 07-27-2008, 10:33 PM
The title is a joke; I just wanted to be a little different from the usual. I wanted to take the time to formally introduce myself. I live near Minneapolis, MN. I'm 25 years old, I grew up around the construction industry. I started working for a GC in the summer of 2001 after graduating high school. Since then I have worked for a couple different GC's, and for a custom home builder which employed 4 crews, which was probably the best thing for me. I learned a lot from different foreman that had learned a lot from different foreman. Anyways I joined this site because it has a wealth of information; I enjoy learning from others experiences. Hopefully I can contribute also.
I would stick with R-13 unfaced with
4mil visqueen.
If you need the R-19 add 5/8-3/4"
foil faced polyisocyanurate.
Lots of jamb extensions and box extenders.
What's wrong with loose fill in the attic?
neolitic is online now   Reply With Quote
The Following User Says Thank You to neolitic For This Useful Post:
genecarp (10-18-2009)
Old 11-09-2009, 10:19 PM   #6
Just wanted to thank the guys who gave me some input. I still have not made up my mind for sure, but I'm thinking that I am going to hire a insulating company to blow in fiberglass. They claim r15 in a 2x4 wall. As far as the attic goes, there is about 350Sq ft of usable living space up there. What do you guys think about furring the roof with 2x8s 24" O.C and blowing the cavities?
-Tony
Foam Insulation - Close and Open Cell AMS Co Insulation 4 10-09-2009 04:08 PM
Bathroom, Insulation, VB etc.... Celtic General Discussion 19 09-13-2009 09:34 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
Pricing questions Brian Painting & Finish Work 3 10-13-2007 08:38 AM
questions on insulation rservices General Discussion 1 12-19-2005 01:30 PM
