Insulation Dilemma
Old 04-15-2007, 11:33 PM   #1
HemiMan2500HD's Avatar
Trade: masonry and general construction
Insulation Dilemma
Ok here is my problem. I gutted the bathroom and 2 of the walls are exterior walls. There is water infiltration under the windows and in the corner of two walls. Also a section of the exterior sheathing is completely rotted. The customer is not having the roof redone yet nor the windows. I can't fix the sheathing from the inside obviously so this is my dilemma. I do not want to put regular fiberglass insulation in the bays( which are 2 x 6 ) for obvious reasons. Only two walls are exterior and require insulation. I want something water resistant so I want to use expanding foam.
The problem is that I don't want the foam to adhere to the exterior sheathing for when it is replaced and the job is so small that no spray foam insulators will do it. What are my options.
HemiMan2500HD is offline
Old 04-16-2007, 06:37 AM   #2
joasis's Avatar
Re: Insulation Dilemma
Water infiltration and the customer isn't concerned yet? Wow!
I suppose you could install 1/2 inch styrofoam in the stud bays, then use foam.....all that comes to mind besides asking the customer if they actually understand the problems with the exterior of their home.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is online now
Old 04-16-2007, 07:03 AM   #3
Yeah it is ridiculous. The exterior is stucco(not the eifs type). The roof is a flat roof that is in terrible shape. I thought about the 1/2 ridgid foam then spray foam. Since it is a small area can I just buy the cans of triple expanding foam and use them.
Old 12-20-2007, 05:25 PM   #4
calnan's energy's Avatar
Trade: insulation window and door contractor
get paid for the work you did so far and run like hell. if you finish the job you will be on the hook for all the damage.
calnan's energy is offline
THrown-in insulation: No soffit vents... Ted W Insulation 19 08-15-2009 12:35 PM
1950s Brick Ranch, No insulation but weird plaster type drwall. personalt Construction 5 01-21-2007 07:49 PM
2000 sf of ceiling...how to remove insulation? carlspackler Remodeling 8 11-26-2006 11:01 AM
Insulation question. Rich Turley Remodeling 14 06-11-2006 03:21 PM
Interesting attic insulation findings IHI General Discussion 5 02-28-2006 02:22 PM
