Insulation Blower HELP
Old 06-11-2009, 10:43 PM   #1
atrebon's Avatar
Trade: General Contractor in Training
Question
Have looked at everything InsulMaxx Krendell Meyers not sure want to get into wall spray never done it
atrebon is offline
Old 06-11-2009, 10:46 PM   #2
solar guy
naptown CR's Avatar
Trade: solar contracting
Re: Insulation Blower HELP
Originally Posted by atrebon View Post
have looked at everything insulmaxx krendell meyers not sure want to get into wall spray never done it
huh?
naptown CR is offline
Old 06-11-2009, 11:03 PM   #3
atrebon's Avatar
My Name is Adam Trebon I work with my father Dave Trebon, Trebon Constuction out of Jesup, IA I want to get into wet spray insulation/ spryed in cavity cellulose Currently all the new homes we build we do with batt insulation, Im trying to figure out what the best machines to buy are. Any help greatly appreciated!!!
atrebon is offline
Old 06-12-2009, 08:21 AM   #4
joasis's Avatar
A Krendl is a good choice, and we run an Insulmaxx 4000. Basically, it will come down to new or used, and then getting the pump, tank, and scrubber...that is the extra equipment you need for wet blown walls. Hope this helps.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 06-12-2009, 06:35 PM   #5
atrebon's Avatar
i have looked at the 4000 and what im trying to figure out is how do u do wall spray without at least 4 ppl one filling machine one spraying one scrubbing one vaccuming how much does your insulmaxx hold in hopper can u get wireless remote?
atrebon is offline
Old 06-12-2009, 06:37 PM   #6
joasis's Avatar
It takes 2 people, and you spray several bays, then scrub. The guy feeding the machine sweeps up and reloads. Simple. Lots of leg work, and easier for 3 guys, but it works. We do not use a vacuum. The guy spraying does the wall scrub....i.e., 1 skilled guy, and a helper that only needs to know how to blend "wet" cellulose with dry in the machine to keep from having a problem. Learn with experience.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline
The Following User Says Thank You to joasis For This Useful Post:
atrebon (06-12-2009)
Old 06-12-2009, 06:51 PM   #7
atrebon's Avatar
ok well i have been looking at also spraying JM spider and they are telling me i need a machine that will hold several bags of insulation that will cost around 20k for 1 of the big meyers machinces or comparitive and im not really sure
atrebon is offline
Old 06-12-2009, 07:08 PM   #8
atrebon's Avatar
i was Thinking about getting a capitol model 100 i found used but not sure if it would work or not
atrebon is offline
Old 10-07-2009, 07:34 PM   #9
parts's Avatar
Trade: Insulation contractor
Best to stick with cellulose and get a Krendl.
parts is offline
Old 10-07-2009, 07:35 PM   #10
parts's Avatar
Most any air lock machine should work
parts is offline
Insulation blower ITS REFRIG Contractor Swap 10 11-06-2011 10:12 PM
Insulation blower ITS REFRIG Tools & Equipment 7 11-03-2010 09:54 PM
WTB: Insulation Blower DCS Contractor Swap 20 07-08-2008 07:39 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
Looking for a good deal on an insulation blower RBS Insulation 0 09-24-2007 10:10 PM
