Insulating RV With Polystyrene
Old 08-01-2013, 10:11 PM   #1
tundrawolf's Avatar
Trade: General
Hello,
I have an RV that has an insulated cavity thickness of 2" (most of the RV) to 1" (The cabover).
I am looking to get the best insulative properties for the money, and I can pretty much afford the polystyrene sheets.
Is there going to be a big advantage to going with the foil covered sheets of polystyrene?
Also, should the entire cavity be filled with the polystyrene, (I.e. for the 2" thick cavities, use 2" thick sheets, for the 1" thick cavities, use 1" thick sheets) or should there be an air gap of some sort to help with the insulative properties?
tundrawolf is offline
Old 08-02-2013, 06:32 AM   #2
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,224
Re: Insulating RV With Polystyrene
The foil only helps if there is an air gap. However, some testing done by the fantastic folks at CCHRC has shown not by very much. If you want some heavier reading, check it out: http://cchrc.org/docs/reports/TR_201...d_Climates.pdf
I'd fill it with the best insulation you can afford. EPS, XPS, or polyisocyanurate
Golden view is offline
Old 08-02-2013, 07:08 AM   #3
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 90
Golden View nailed it - just make sure there are no gaps / voids / places where water can condense & sit
SLSTech is offline
Old 08-03-2013, 12:08 AM   #4
tundrawolf's Avatar
Trade: General
Okay, thanks!
Which one of those above has the highest R factor?
And, I want to completely fill the void, right?
Old 08-06-2013, 08:34 PM   #5
GTHill's Avatar
Rewards Points: 119
Wondering if someone can answer the above question? I have a similar situation and would appreciate advice!
GT
GTHill is offline
Old 08-06-2013, 09:27 PM   #6
edward trowelhands
Trade: Diplomat
Polyiso sheets or closed cell polyurethane foam if you are spraying it in.
Old 08-06-2013, 09:40 PM   #7
tundrawolf's Avatar
Trade: General
If I have a inch and three quarter thick gap, should the sheet be inch and three quarters thick?
Old 08-06-2013, 10:01 PM   #8
edward trowelhands
Trade: Diplomat
Sorry, didn't answer your full question. It would provide the most insulation if you filled the cavity, but it won't hurt too much if it doesn't quite. So an inch and a half sheet in the 1 3/4 cavity would be fine.
tundrawolf (08-06-2013)
Old 08-06-2013, 10:03 PM   #9
tundrawolf's Avatar
Trade: General
Thank you very much
Old 08-07-2013, 04:52 AM   #10
Sean
SLSTech's Avatar
Rewards Points: 90
You really should fill the complete cavity so you don't have a condensing surface inside the bay - a lot depends though on where you store & use your RV
SLSTech is offline
Insulating attic question power Insulation 19 03-10-2013 07:55 PM
Insulating Walls - what if ???? power Insulation 6 03-08-2013 09:12 AM
Insulating a cape cod second floor rizzoa13 Insulation 7 01-24-2013 07:25 PM
Insulating a Cathedral Roof Anderson Roofing 37 11-28-2011 07:43 AM
Insulating a timber stud cavity wall - Query? AlanC Insulation 1 05-08-2010 11:58 PM
