Trade: Deck builder /contractor
Insulating From Outside
Any recommendations on insulating from outside? I'm installing new siding and while Im at it ,since I only have 2x4 walls, thought I would try and improve the heat bill. Ive considered P2000, bubble wrap, and just regular 5/8 foam sheets. This is on my own home. I have never done anything like this for a customer, so I have never really researched it before.
strat hd
Trade: framing contractor , remodeler , GC occasionally
Re: Insulating From Outside p 2000 insulation There's a lot of controversy going on about p2000. I was going to use it on a job but changed my mind. |
I'm a Mac
Trade: ICF Construction
Wrap the house with 1 1/2" EPS Ship Lap. It's a bit of work to modify the windows and doors but definately an improvement. Make sure you seal really good at the foundation.
Chris |
Wrap the outside wall in some extruded polystyrene, tape all joints. Strap and Side it.
If that isn't enough, you can always go to the inside, take the drywall down, strap the walls horzontially over the existing vapour barrier, and insulate the cavity's, then drywall over that. Just remember by code (this is Canadian of course) its all about 3rd's. 2/3 of the wall insulated and vapour barriered, 1/3 can be insulated in front of the vapour barrier. Should up the R-Value for ya. -Bill
You laugh because I'm different........... I laugh cause I just farted! |
Sean
What is in the walls now? If there empty, I would look into blown in celluse or slow expanding foam. If the sheathing has to go, maybe strip out the old & see above.
#6 | |
I'm a Mac
Re: Insulating From OutsideQuote:
I believe you meant Expanded PolyStyrene (EPS) not Extruded (XPS) XPS will 'dry' and shrink leaving gaps between the sheets within a short time
Chris |
Tech Geek
Trade: Property Management/Facilities Manager
Re: Insulating From Outside |
Eater of sins.
Trade: Designer/Drafter Extrordinaire
Excuse a dumb question but why not use R-13 glass?
Andy. |
#9 | |
#10 | |
#11 | |
Sorry about that.
How about the bubble wrap? Would that help anything installed on the outside of the home?
Trade: Energy Renovation / Masonry
Use polyisocyanurate, more commonly known as foil backed board, or high R. this has a R value at installation of around 8 per inch when installed, and drops down to around 7 eventually.
if no insulation exists, I suggest having cellulose dense packed into the wall cavities. before either of these, AIR SEAL. Good luck |
| Expanding My Company by Offering Insulating. | kbconstruction | Insulation | 3 | 04-06-2009 07:03 PM |
| deck to addition - insulating the floor | Tickridgescott | General Discussion | 6 | 04-03-2009 11:34 PM |
| SW insulating paint | sparehair | Painting & Finish Work | 21 | 02-04-2009 08:50 PM |
| Looking for ideas for insulating craw duct work. | Veith@toast.net | HVAC | 15 | 01-21-2009 07:34 PM |
| Insulating Roof and To Vent Or Not To Vent | Morning Wood | Construction | 3 | 11-03-2008 08:39 PM |
