Insulated Subfloor Question.
Old 01-05-2009, 11:00 PM   #1
Framing 2 Finish
rock-it man's Avatar
Trade: Steel stud framer/ renovator
I recently finished a project where I used a 2x2 subfloor system called barricade. It uses a 1/2 inch of xps foam with 5/8? osb glued to it with tounge and groove on all four sides. It is a great idea, but a PITA to install. I've been contemplating laying the same products, but with sheet goods. Problem is, I would like to keep everything floating, with no fasteners in the concrete. 4x8 T&G osb only has the T&G on the 8' side and I'm trying to figure out how to fasten the butts. Biscuts? maybe a half lap joint with the router, glued during install. Any ideas? Ive also thought of using two layers of 1/4 or 3/8 staggered, glued and stappled, but decided against it due to cost and labor. Any insight would be appreciated.
rock-it man is offline
Old 01-05-2009, 11:19 PM   #2
Tom Struble's Avatar
Trade: siding
Re: Insulated Subfloor Question.
maybey remove some foam and add a rip of 1/2 ply as a spline?
Tom Struble is offline
Old 01-05-2009, 11:25 PM   #3
Framing 2 Finish
Thats something I hadn't thought of. Not a bad idea. Simple too...I like Anybody else???
Insulated headers karma_carpentry Framing 43 10-17-2010 05:21 PM
Insulated Siding and Marketing Patrick Windows, Siding and Doors 21 08-07-2008 01:31 PM
Insulated Boot sjm-sc HVAC 0 06-11-2008 12:50 PM
Insulated glass shortage ChuckEA Windows, Siding and Doors 1 01-18-2006 08:10 AM
