Icynene And Batt Combo
Old 06-18-2009, 11:25 PM   #1
go do it's Avatar
Trade: general contracting
i need to have my roof re-insulated (long story) and one insulator i talked to wants to spray 3/4 icynene to get an air tight seal and then use batt for the r-value ,i guess.
i have never heard of this befor. i am a certified green professional from the NHBA and i sure as hell don't know everything but i don't like this idea.
anybody have any thoughts or have used this system?
go do it is offline
Old 06-19-2009, 09:21 AM   #2
Sean
SLSTech's Avatar
Re: Icynene And Batt Combo
It has to be CLOSED CELL foam (tested & approved - i.e. Demilic) - Icenyne is open cell
Splash & Dash is a trick to keep costs down (CC foam followed by OC foam, or batts, etc...)
You might want to check out the building science website, or pull a few searches on here
I have not used a splash & dash system - I went with straight Closed Cell & an ERV to introduce Fresh air
http://www.sls-construction.com/Phot...Insulation.pdf for the insulation page only
http://www.sls-construction.com/Photobook.htm - the full photobook
SLSTech is online now
Old 06-19-2009, 06:54 PM   #3
go do it's Avatar
thanks for the info
by the way you have a nice site
go do it is offline
