Foam Or Stuff.
Old 10-21-2006, 07:33 PM   #1
InsulPro's Avatar
Trade: Insulation Installer/Building Contractor
Foam Or Stuff.
Do you guy's foam or stuff your windows?
InsulPro is offline
Old 10-21-2006, 08:13 PM   #2
Teetorbilt's Avatar
Re: Foam Or Stuff.
Foam everything. Doors, windows, whatever. Can go to 12#, bad A stuff and requires bracing until it's set. Near bulletproof after that.
Albert Einstein
Teetorbilt is offline
Old 10-21-2006, 10:35 PM   #3
Steve Unkie's Avatar
Trade: REMODELING CONTRACTOR
Re: Foam Or Stuff.
I've always used foam, but my crew gives me a hard time. They like stuffing. I don't get it.
Steve Unkie.
Steve Unkie is offline
Old 10-21-2006, 10:40 PM   #4
Remodeler Extraordinare
A.W.Davis's Avatar
Re: Foam Or Stuff.
For doors and windows I use the non expanding spray foam so it doesnt bow the window flange or door jamb.
For thin spaces in between studs on exterior walls I use the expandable spray foam.
A.W.Davis is offline
Old 10-21-2006, 11:17 PM   #5
mdshunk's Avatar
Re: Foam Or Stuff.
Not to derail the thread, but on a related note: What's the name of the "system" where the foam comes in a container that looks like a BBQ grill propane tank, and has a wand sort of like the exterminators use to spray for bugs? I'd sorta like to look into getting a rig like that for draft stopping my top and bottom plate penetrations.
mdshunk is offline
Old 10-22-2006, 02:33 AM   #6
Moderator
Double-A's Avatar
Re: Foam Or Stuff.
There are several types. Search "Foam Insulation Kits" and you'll find them.
New York Times, July 20, 2006
Double-A is offline
Old 10-23-2006, 09:31 PM   #7
IHI's Avatar
Re: Foam Or Stuff.
All depends for us. On new construct I size RO enough to leave a nice gap to get the plastic tube in the store bought foam cans in without problems. On my spray foam gun that uses the screw in foam cans I made a tip out of copper water line and smashed it with a hammer to try on replacement windows that have tight gaps around them...it worked okay on some, and others it made a mess. So for all my replacment windows I stuff them with batt. In all these years I have never once had a call back for air coming in so there's no changing my mind that stuffed works every bit as good as foam as far as stopping 99% of air infiltration.
But the foam is faster..even though it costs 5x's as much to do it that way
IHI is offline
Old 10-23-2006, 10:49 PM   #8
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Re: Foam Or Stuff.
Foam on windows and fiberglass on doors.
dougchips is offline
Old 10-23-2006, 11:02 PM   #9
Painter
camaroman2125's Avatar
Trade: Painter
Re: Foam Or Stuff.
I stuff all our doors and windows.
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
camaroman2125 is offline
Old 10-24-2006, 09:00 AM   #10
wolffhomerepair's Avatar
Trade: General Remodeling
Re: Foam Or Stuff.
I've always foamed on both windows and doors.
http://www.wolffhomerepair.com
" Of course I don't look busy, I did it right the first time "
wolffhomerepair is offline
Old 12-01-2006, 09:59 PM   #11
Davey's Avatar
Trade: Custom Interior Finishing
Re: Foam Or Stuff.
FrothPak
Davey is offline
Old 12-15-2006, 01:06 AM   #12
axnjoe's Avatar
Trade: Interior contracting
Re: Foam Or Stuff.
Foam all
axnjoe is offline
Old 12-20-2006, 07:50 PM   #13
TimNJ's Avatar
Re: Foam Or Stuff.
I foam all doors and windows. IMO, if somewhere down the line water starts to get in that fiberglass will be like a wet rag in the wall.
TimNJ is online now
Old 05-19-2007, 07:10 PM   #14
cbtexas's Avatar
Trade: Marketing
Re: Foam Or Stuff.
We foamed all our windows and doors
cbtexas is offline
Old 07-26-2007, 11:31 AM   #15
comp1911's Avatar
Trade: Mechanical Engineer
Re: Foam Or Stuff.
foampower dot com
handi foam
comp1911 is offline
Old 07-26-2007, 12:51 PM   #16
Professional Remodeler
firemike's Avatar
Re: Foam Or Stuff.
I foam everything I can. Have the Hilti foam gun.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 07-28-2007, 07:46 PM   #17
MSSI's Avatar
Trade: Electrician
Re: Foam Or Stuff.
Tigerfoam.com Has firerated foam Im sure others do as well
MSSI is offline
Old 11-11-2007, 02:30 PM   #18
TomHay's Avatar
Re: Foam Or Stuff.
I am partial, I like foam and BIO.
Any questions feel free to ask
Thanks,
TH
TomHay is offline
Old 11-11-2007, 05:06 PM   #19
oldfrt's Avatar
Re: Foam Or Stuff.
I like stuffing them.
The insulation can be free;
On new construction,take a couple bags of the cut-offs from the insulation installers.On most sites here ,these are always discarded,already bagged, when the job is done.
They're usually long thin strips and easily installed.
If you know an insulation contractor,have him set some aside for you.
Having it on hand is one less stop for me on the way to the job site.
So you save twice,time and material.
oldfrt is offline
Old 11-11-2007, 05:09 PM   #20
Home Serve's Avatar
Trade: siding windows soffit fascia
Re: Foam Or Stuff.
We stuff them too. Maybe old fashioned way but done right very effective and a lot less messy.
No reason for it to get wet any more than anything else. If you got wet you got troubles anywho.
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Foam Board vs. OSB JimmyZimmier Framing 17 11-06-2010 05:54 PM
Gutter Stuff Foam minnesotaroofin Roofing 7 01-28-2008 09:19 AM
Spray foam insulation? tgeb Insulation 5 12-16-2007 11:11 PM
What stuff you have bent on your brake dkillianjr Tools & Equipment 0 08-14-2007 06:59 PM
Isulating with Foam for Roofs? FrankJr Construction 2 03-25-2006 10:05 PM
