Trade: General Commercial Construction
Fireproofing Sparyed Foam
Hi, I was hoping someone here knew a definite answer to this question or a place I can find one.
Building: A commercial building 1 story, flat roof, metal deck, structure is steel. The exterior is drywalled and the air/vapour barrier is applied onto the outside of the exterior drywall. The roof is a rubber membrane. To complete the insulation a spray foam was used on the steel that supports the roof at the top of the walls. The walls are not rated wall on the inside. On the interior the drywall is 3/4" shy of the decking to allow for deflection. This leaves a 3/4" gap of exposed foam. The foam is Polar Foam 7300 Does this foam need to be fireproofed? Thanks for any help. Last edited by canuck; 11-11-2008 at 08:45 AM. |
Trade: Spray Foam Insulation
Re: Fireproofing Sparyed Foam
If the foam is left exposed in a occupied space that I do believe that it will require some sort of fireproofing cover. if the drywall is applied overtop of the foam that as long as it is fire-rated then you should be good. You can contact CPi - Construction Polymers with such questions and their Building Science department can help answer such questions.
#3 | |
Re: Fireproofing Sparyed FoamQuote:
1) Flame spread of the exposed foam 2) "Not rated walls on the inside". I have seen details that were rated on one side, and not the other, but have never been even remotely involved in such as structure. Most locations have been residential garages, where the exterior siding has no rating. Is your exterior a rated assembly? This could be the case where you encroach on the property line closer than an arbitrarily defined limit, generally 5'. Such encroachments are common in commercial work. If so, I would think that the rating of the exterior is going to become dragged into the interior |
Trade: Foam/FP/FS/etc.
It most certainly does.
Regardless of the rating of the wall you simply cannot leave foam exposed. It must have rated drywall or spray applied thermal barrier applied over it. http://www.adfire.com/FP%20products/...0171108%20.pdf That is a spec sheet for a product that will bring you up to code. |
| Spray foam question | NCDeere | Insulation | 16 | 01-22-2010 12:15 PM |
| Rigid Foam Cutters | manulind | Insulation | 4 | 11-04-2008 10:02 PM |
| OSB with rigid foam board factory attached | im4snow | Framing | 1 | 10-29-2008 09:22 PM |
| Removing Spray Foam Insulation? | CO2Solutions | Insulation | 3 | 09-21-2008 10:33 PM |
| Spray Foam Damage - HELP! | crawfobc | Insulation | 4 | 07-04-2008 10:07 PM |
