agboett
Guest
Posts: n/a
Exterior Blown In/ Floor Joists
I need to blow in insulation into floor joists from the exterior. A finished cieling below and a 2nd level above.
I need advice/tricks on how to stop or block the insulation roughly 2 feet into the floor joist cavity before I blow in insulation? Advise is very appreciated |
parts
Guest
Posts: n/a
Re: Exterior Blown In/ Floor Joists
Why does it have to stop two feet in? Unless you make a hole big enough to get your hand in I am not sure how you could do this
doubleaction
Guest
Posts: n/a
Hard pack with fiberglass batts?
parts
Guest
Posts: n/a
But you would need a hole big enough to do that
