E Shield Insulation
Old 01-06-2010, 07:14 AM   #21
buddy110's Avatar
Trade: Exteriors as a whole
Send a message via AIM to buddy110
Re: E Shield Insulation
Originally Posted by booschang View Post
Important notes for the DIY... ALWAYS leave an air space on both sides of the barrier. If you don't, heat will conduct through the barrier and your results will be less than optimal. NEVER seal edges and seams. Your structure needs to breathe.
Actually there's sufficient "ir space"within the fiberglass. laying the RB on top of FG will not cause it to conduct. I have proven this time and time again with a heat lamp.
Otherwise you are 100% correct
buddy110 is offline
The Following User Says Thank You to buddy110 For This Useful Post:
Tom Struble (01-06-2010)
Old 01-13-2010, 09:15 PM   #22
Windows Plus
Kenny K's Avatar
Trade: Replacement of windows,siding and doors
good explanation,
Kenny K is offline
Old 01-22-2010, 09:56 PM   #23
tedfialla's Avatar
Trade: Home Improvement
I've been installing the e-shield product here in Fla for 2 years and all my customers see a 30-40% reduction in their energy bills once it is installed i swear by this product.
tedfialla is offline
The Following User Says Thank You to tedfialla For This Useful Post:
Kenny K (01-31-2010)
Old 02-08-2011, 04:59 PM   #24
InsulationCo's Avatar
Trade: insulation
We use the "2 ply" RB with fiberglass in between the RB being a in the ohio region i am not sure the how effective it is in this area for "conventional" attics. we use it mostly for "Cape Cod" type of home and have seen great results.
InsulationCo is offline
Old 02-08-2011, 05:02 PM   #25
buddy110's Avatar
Yeah it's more usefull in the southern regions.
buddy110 is offline
Old 02-20-2011, 08:34 PM   #26
enforcer's Avatar
Trade: windows-siding
i guess thsi stuff is like having lowE glass in your attic? if reflects radiant heat from the heater back into the home and in the summer reflecting the radiant heat back away from the home?
in the attic,does this stuff go on the floors or just the ceiling? can it be used anywhere else in the house?
enforcer is offline
Old 02-20-2011, 10:27 PM   #27
ASInsulation's Avatar
Trade: Insulation and Weatherization
i firmly believe that the reflective barrier is going to be far more effective in retaining a cooler temperature in your home then trying to achieve a warmer one...in the case of trying to warm the home, it won't be cost effective...down south, where your cooling season is longer and more extreme, definately worth the investment
ASInsulation is offline
Old 02-21-2011, 12:59 AM   #28
enforcer's Avatar
is the radiant barrier best layed on top of the insulation in floor of attic or in rafters?
in the northeast, can radiant barrier be detrimental in any way?
what if you have a small roof leak, can the radiant barrier get ruined if its wet?
enforcer is offline
Old 02-21-2011, 06:20 PM   #29
windows & siding
HomeSealed's Avatar
Trade: Home Performance: windows and exterior remodeling
Either or. Depends on the which product used, and the circumstances of the home.
HomeSealed is offline
insulation types for new buildings sprayseal General Discussion 14 10-12-2009 07:14 AM
Foam Insulation - Close and Open Cell AMS Co Insulation 4 10-09-2009 05:08 PM
Bathroom, Insulation, VB etc.... Celtic General Discussion 19 09-13-2009 10:34 PM
Need some expert advice for attic insulation bean Insulation 1 03-12-2009 03:42 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
