Do You Vent An Attic Which Has Wet Spray?
Old 06-25-2008, 11:50 AM   #1
d-rez's Avatar
Trade: general contractor
Rewards Points: 150
The title says it all. The architect is telling me that an attic that has a wet spray insulation should not be vented. This seems so wrong to me but I am new to the Icynene type insulations? Thanks, -Chris
d-rez is offline
Old 06-25-2008, 12:06 PM   #2
Joasis's Avatar
Rewards Points: 1,378
Re: Do You Vent An Attic Which Has Wet Spray?
Is the attic considered to be "conditioned" space, meaning the spray foam is applied to the underside of the roof decking?
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is online now
Old 06-26-2008, 06:30 AM   #3
d-rez's Avatar
Rewards Points: 150
Yes, Joasis, insulation would be sprayed in the rafter bays, not ceiling joists. I would not consider it 'conditioned space' though, the intent is not to air condition the attic.
d-rez is offline
Old 06-26-2008, 06:53 AM   #4
genecarp's Avatar
Rewards Points: 2,000
it is a new way of approaching residential insulation, lock the house down, then provide fresh air exchange
genecarp is offline
Old 06-26-2008, 09:22 AM   #5
Ed the Roofer's Avatar
Trade: Roofing Contractor
Rewards Points: 2,054
The architect is following a newer wave of Building Science theory.
Check out www.BuildingScience.org for a lot of information on it.
Ed
Ed the Roofer is offline
Old 06-26-2008, 07:37 PM   #6
d-rez's Avatar
Rewards Points: 150
Thanks guys. I met with my insulation sub and he confirmed that it should not be vented. -Chris
d-rez is offline
Old 09-04-2008, 09:31 AM   #7
rodeo's Avatar
Trade: commercial, apt. & mobilehome maiontenance
d-rez brings up a great point with sprayed cellulose.
According to IRC 806.4 (2007 supplement), unvented attics are allowed under certain conditions. It seems like SPF is the only candidate for applying impermeable insulation first on the decking underside. Only SPF has both air and vapor barrier properties.
There is some confusion as to wether sprayed cellulose meets the 806.4 requirements. Its an air barrier but not a vapor barrier. In fact, cellulose abosrbs and holds quite a bit of moisture. It supposedly will dry out during warm months but it sounds a little strange still.
It would be great if sprayed cellulose could be used here instead of SPF, as its much cheaper. I have a suspicion that sprayed cellulose will work but only with increased ventilation compared to SPF. The SPF may be able to take higher humidity loads than the cellulose.
rodeo is offline
Old 09-04-2008, 10:07 AM   #8
JimE's Avatar
Trade: carpentry
No venting. Jim.
Brookfield Maid
JimE is offline
Old 09-04-2008, 02:57 PM   #9
Preserving the Past
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Rewards Points: 2,060
Now you need to ask if it's open or closed cell insulation. That should start some good debate!
Welcome to the world of Building Science
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 09-05-2008, 10:04 PM   #10
CO2Solutions's Avatar
Trade: Dry Ice Blasting
Rewards Points: 154
ok, help me out with this one then. I'm working in a crawlspace at the moment in which mould was formed. The space is basically like a minature basement, poured floor and foundation and spray foam on the underside of the flooring. I'm assuming that it would need air flow as well to prevent mould from forming again? air exchanges required in the crawl space?
thanks,
mike
CO2Solutions is offline
seal gable vents after ridge vent installed? tacoma5050 Roofing 41 06-07-2012 07:32 PM
attic fan or ridge vent dlcj Roofing 29 06-15-2010 06:39 AM
Frost inside the attic? SOSSW Roofing 22 04-03-2009 07:26 AM
Gabled attic vent & door Michaeljp86 General Discussion 4 06-13-2008 09:59 PM
Ridge vent issues? apkole Roofing 4 05-08-2007 05:46 PM
