Cheap Spray Foam Cutting Tools
Old 05-22-2010, 05:23 PM   #1
sbcontracting's Avatar
Trade: General Contracting
Rewards Points: 562
Ok, I just spray foamed a bathroom, not realizing how rigid the stuff would be. I used a Tiger Foam 600 bd ft kit, I figured I needed about 300 board ft. Turned out I needed most of it... Tanks might have been a bit on the cool side... but anyways, it's in now.
Cutting is a challenge. I don't want to go out and buy a crazy expensive cutter. Basically I have to go with a home-depot solution, as they are the only guys open tomorrow.
What's best? I was thinking of getting an extra long blade for my sawzall. Another option might be an old-fashioned hand saw.
Any other options?
sbcontracting is offline
Old 05-22-2010, 05:25 PM   #2
Rewards Points: 562
Re: Cheap Spray Foam Cutting Tools
Note: I filled the 2x4 wall and 2x4 rafters... there is 0-2" extra just about everywhere. Not an easy thing to do cleanly! :/
Old 05-22-2010, 05:27 PM   #3
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
I'd try a nice old handsaw, not too fine. I'd think the more aggresive to teeth, the better.
loneframer is offline
Old 05-22-2010, 05:30 PM   #4
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
maybe a bow saw...you know the kind for cuttin tree limbs
Tom Struble is offline
Old 05-22-2010, 05:37 PM   #5
Taylor8's Avatar
Trade: Insulation
Rewards Points: 75
Don't bother with buying any fancy tools, for years all I used for trimming is long serrated blades with some tuck tape on the end as a handle. Since you probably already own a a hand saw, thats what I would use.
Taylor8 is offline
The Following User Says Thank You to Taylor8 For This Useful Post:
sbcontracting (05-22-2010)
Old 05-22-2010, 06:07 PM   #6
Working
Cole82's Avatar
Rewards Points: 2,276
Foamzall!
gos in your sawzall
http://store.contractor-pro.com/foam...36-p-2826.html
Cole
The boss of awesome
Cole82 is offline
The Following User Says Thank You to Cole82 For This Useful Post:
Old 05-22-2010, 06:49 PM   #7
Rewards Points: 562
I like that puppy, I don't know if the despot will carry that. Longest sawzall blade I've seen in a store is about 12".
I bought a tree saw blade, gonna duck tape the ends. It doesnt work that well though... gonna try a rough tooth saw as well. Something with a pointy tip would probably be best.
Old 05-22-2010, 08:09 PM   #8
parts's Avatar
Trade: Insulation contractor
Rewards Points: 150
The last job I was on with it they used an angle grinder with a knotted wire brush
parts is offline
Old 05-23-2010, 12:07 PM   #9
Taylor8's Avatar
Trade: Insulation
Rewards Points: 75
Is that the same crew that let a GC spray with no mask?
Taylor8 is offline
Old 05-25-2010, 06:31 AM   #10
parts's Avatar
Rewards Points: 150
Yeah but it got it off the rafters really well
parts is offline
Can closed cell spray foam be used as a water proof vapor barrier in a shower? Mike Finley Construction 16 10-09-2009 04:14 PM
Spray Foam Fluorocarbons 10fingers Insulation 1 10-09-2009 04:06 PM
spray foam quesion mikeybobo Insulation 1 06-16-2009 08:40 AM
