Cellulose And Weight = Problem?
Old 01-09-2009, 07:06 PM   #1
tgeb's Avatar
I am having some additional insulation blown into my attic.
I got 2 quotes and both contractors quoted fiberglass instead of cellulose, from my research here and other places I understand that cellulose is better.
When I brought this up the contractor who I intend to use said he did not like to put cellulose in the attic due to the weight of the material. (he will be adding R-19 on top of what is there, to a total of R-38. But some places actually have none at this time, so those areas will be R-38 cellulose)
My attic framing is "stick built" 2X6 for ceiling joist and 2X8 rafters, 16" centers, but only 3/8" sheet rock above the living spaces.
Do you think this will present an issue some where down the road? I don't want my ceiling looking like a wash board in a few years.
Price is the same with this so the only issue is....Is cellulose the right thing in this application.
And no I'm not going over to DIYChatroom.
www.gebcon.com
tgeb is offline
Old 01-10-2009, 12:49 AM   #2
WXdan's Avatar
Trade: weatherization tech
Re: Cellulose And Weight = Problem?
Hi tgeb,
I'm gonna guess that your contractor doesn't usually stock cellulose, and that's why he's pushing the fibo. Blown cellulose goes at (conservatively) R 3 per inch. If you are looking for R 38, you are going to have at the most 13 inches of cellulose at a density of less than 2 pounds per cubic foot. Some simple math...tells me that that will end up being a little over 2 pounds per square foot of ceiling area (1'x1'x13"). No worries on the sheet rock. The place I work for has been blowing cellulose since the 1980's and the only ceiling weight issues we have is when one of our techs puts his foot through the ceiling.
A side note, whatever you blow in an attic will get into the home occupant's lungs (uncomfortable for us insulators to say, but true). I would rather breath cellulose (recycled newspaper with borax) than fiberglass.
WXdan is offline
Old 01-10-2009, 08:07 AM   #3
DavidC
DavidC's Avatar
We choose cellulose over FG at every opportunity. IMHO it's simply a better product that has fewer install problems. I agree with WXDan's assessment.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 01-10-2009, 09:05 AM   #4
TimelessQuality's Avatar
Trade: GC/Remodeling
3/8" rock may sag over time... Especially if you have a high humidity area (bath) or event (water leak).
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is offline
Old 01-13-2009, 07:53 PM   #5
tgeb's Avatar
Thanks for the feed back guys. How ever I made a mistake in the R value I quoted in the original post, and we actually should have R-49 total in this attic.
Does this change your opinions at all?
www.gebcon.com
tgeb is offline
Old 01-14-2009, 12:11 AM   #6
WXdan's Avatar
No opinion change from me.
WXdan is offline
Old 01-14-2009, 06:42 AM   #7
DavidC
DavidC's Avatar
Same here. I have more than that over my own kitchen.
Good Luck
DavidC is offline
Old 01-14-2009, 08:13 AM   #8
bighammer's Avatar
Trade: Lead Nail Bender....
intake, exhaust, proper vents, make sure you have adequate ventilation...you could ruin everything if this is not done properly.
I wonder why they used 3/8" SR on the ceiling areas? Good luck and keep us posted on what you do...
bighammer is offline
Old 01-27-2009, 07:55 PM   #9
parts's Avatar
Trade: Insulation contractor
Weight should not be a problem with 3/8 Sheetrock when it's 16 OC. The 3/8 is existing? Or to used just to match whats there already?
parts is offline
