Cellulose Over Loose Fill Fiberglass
Old 02-28-2011, 12:58 PM   #1
Crank's Avatar
Trade: Home performance / Log home repair/maintenance
Rewards Points: 25
I am just getting into the industry and have looked at several attics that have 2-4 inches of loose fill fiberglass. After air-sealing and other prep work, is it advisable to blow cellulose over the existing insulation.
Crank is offline
Old 02-28-2011, 01:25 PM   #2
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Re: Cellulose Over Loose Fill Fiberglass
yes
Framer53 is offline
The Following User Says Thank You to Framer53 For This Useful Post:
HomeSealed (03-07-2011)
Old 02-28-2011, 01:47 PM   #3
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 98
Loose fill? You are fine with two caveats --- (as you mentioned) make sure you do the air-sealing work first (holes for wiring, plumbing, where the walls are, etc...) & no rodents or other critters have used it as an outhouse, home
As for batts - the answer is no
SLSTech is offline
Old 03-02-2011, 10:11 AM   #4
millshome's Avatar
Trade: Home energy retrofits
I would advise adding more loose-fill fiberglass rather than cellulose for several reasons. 1) Even though cellulose is a good insulator, because it is essentially ground up newspaper it has fire retardant chemicals added to it. Those chemicals can corrode wiring and will also be "washed" away over time as moisture collects on the insulation and then evaporates, leaving you with a fire hazard in the attic. 2) Cellulose is dusty and dirty compared to fiberglass and is much messier when its installed. You have to mist water as you install cellulose to keep the dust down...
Modern fiberglass is relatively user friendly, is guaranteed not to settle and has a lifetime manufacturers warranty...
Just my two cents.
millshome is offline
Old 03-02-2011, 10:17 AM   #5
Joasis's Avatar
Rewards Points: 1,466
Just my two cents.
Really? I would like to see your source for those statements. Corrosion of wiring and it becomes a fire hazard?
Before you cash the check for your 2 cents, you may want to consider the accuracy of what you post.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
The Following 2 Users Say Thank You to Joasis For This Useful Post:
HomeSealed (03-07-2011), SLSTech (03-02-2011)
Old 03-02-2011, 10:49 AM   #6
millshome's Avatar
Here is a reference regarding the washing away of the fire retardant material. It doesn't specifically say "fire hazard" but it makes sense to me that if fire retardant chemicals are washed away from a flammable material, the result would be an increased risk of fire.
energysavers.gov/your_home/insulation_airsealing/index.cfm/mytopic=11660[/url*
We've heard numerous stories similar to this one regarding the corrosiveness of cellulose chemaxx.com/cellulose.html[/url]
Old 03-02-2011, 12:50 PM   #7
Joasis's Avatar
My point exactly:
Manufacturers add chemicals to the cellulose to make it insect and fire resistant. The major disadvantage of cellulose is that it absorbs more water than fiberglass or mineral wool. This can become a problem if water leaks from the outdoors since cellulose wicks water into itself and stores it. Too much water can also wash away the fire retardant.
How much water is too much in an attic? The amount needed to "wash" the borate from cellulose would destroy the sheetrock and cause significant damage, yes?
Fiberglass is poor second as an insulation choice in construction, compared to cellulose...and independent studies, not from Owens Corning, confirm this.
I have yet to hear anything about corrosion caused by cellulose.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Joasis is offline
The Following User Says Thank You to Joasis For This Useful Post:
Old 03-21-2011, 09:02 PM   #8
Crank's Avatar
Rewards Points: 25
Why is the answer no for batts?
Crank is offline
Old 03-29-2011, 07:53 PM   #9
c gerard's Avatar
Trade: general
Rewards Points: 25
Blown cellulose or fiberglass are both good if done properly ( critters wont burrow in cellulose because of the boric acid) not that it matters. If the attic is properly vented there is no issue with either. If either gets wet from a leak they have to be replaced regardless.
c gerard is offline
Loose ends? Mike's Plumbing Business 7 09-25-2010 09:45 AM
blown in cellulose versus blown in fiberglass? bmf5150 Construction 8 09-08-2009 09:23 PM
Price for Fill / Garage Slab Prep -- Opinions? slr2974 Excavation & Site Work 9 06-17-2009 09:22 AM
Cellulose and weight = problem? tgeb Insulation 8 01-27-2009 06:55 PM
cellulose vs fiberglass insulation Home Serve Insulation 3 09-20-2008 06:48 AM
