Attic Insulation
Old 11-05-2009, 09:41 PM   #21
mics_54's Avatar
Trade: contractor
Re: Attic Insulation
It isn't necessary.
Not here.
Water vapor travels from the higher
concentration to the lower concentration.
It does not require heat transfer.
There is no difference in heat loss whether
there is R-38 with vapor retardant, or R-38
with out vapor retardant.
WRONG!
Air traveling through every little hole in the walls and ceiling results in heat loss silly man.
mics_54 is offline
Old 11-05-2009, 10:16 PM   #22
72chevy4x4's Avatar
why would you buy insulation from Lowes? I just bought R19 24" unfaced for $0.26/sqft from SPI-box stores charge a healthy markup because they know DIY homeowners will buy the goods.
72chevy4x4 is offline
Old 11-06-2009, 10:06 AM   #23
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Originally Posted by Rennovator View Post
Ok im getting the faced R-30 with the paper facing the floor from Lowes
If you're buying that stuff from Lowes why not just buy the blown in insulation from them and blow it in? They even give you the machine for no charge to do it.
You'll be done in 1/3 of the time and have a better final product. You can achieve R-60 easily by standing there with a hose in your hand, maybe even smoking a cigarette and having a beer while you are doing it.
Mike Finley is offline
The Following User Says Thank You to Mike Finley For This Useful Post:
mics_54 (11-06-2009)
Old 11-06-2009, 12:18 PM   #24
SC sawdaddy's Avatar
Mike, are you saying that blown insulation is.......better?
SC sawdaddy is offline
Old 11-06-2009, 01:14 PM   #25
Chief Toilet Mover
Betterer in regard to I can stand there with a cig and a beer holding a hose and fill the attic to the top if I wanted to for as much R value as I want. Betterer in regard to not having to crawl all over the place, cutting batts and stuffing them and getting all itchy and pissed and then having to add more across those to gain more R-value if wanted.
Old 11-08-2009, 02:06 PM   #26
Jeff
jkfox624's Avatar
Trade: master turd burglar
For what its worth i dont think i've ever seen any insulation installed without a vapor barrier regardless of walls floor or attic. Must be a regional thing.
jkfox624 is offline
Old 11-09-2009, 11:43 AM   #27
Drywallers there always staple up visqueen
before they hang flat ceilings for blow-ins?
neolitic is offline
Old 11-11-2009, 08:04 PM   #28
Jeff
jkfox624's Avatar
99% of its kraft faced batts and the rest is visqueen before drywall.
jkfox624 is offline
Old 12-20-2009, 06:41 PM   #29
Windows Plus
Kenny K's Avatar
Trade: Replacement of windows,siding and doors
how about the radiant barrier mult reflecive, r vaule of 11 add to insulation anyone hear of this concept?
Kenny K is offline
Old 12-20-2009, 06:48 PM   #30
Framer53's Avatar
Trade: Framing
R value of 11 from radient barrior?? Better check on that number.
Blown cellulose is better than fibreglass as there is very little air movement in it.
Framer53 is online now
Old 12-20-2009, 07:16 PM   #31
buddy110's Avatar
Trade: Exteriors as a whole
Send a message via AIM to buddy110
Yep we use it and it's a R11.6
It's called eshield
It's fiberglass with a reflective film on both sides. It's legit
buddy110 is offline
Old 12-20-2009, 07:25 PM   #32
Framer53's Avatar
Trade: Framing
It's called eshield
Buddy, looked everywhere at their web site , can't find quoted rvalue, just some vague talk about e value. Not saying it isn't valid, but I have never heard of it before.
Found it. I would like to know how 1/4" of fibreglass can = r11.6.
Old 12-20-2009, 07:31 PM   #33
buddy110's Avatar
http://eshield.net/eshield11k.html
It's a combination of reflective and convective technology . Much like the insulation found in an oven
Heat is reflected back to it's source much like Low E in glass. Low E can produce and R of 9.9 all by itself.
buddy110 is offline
Old 12-21-2009, 06:33 PM   #34
Windows Plus
Kenny K's Avatar
It's called eshield
Yay that is is it, guardian product, would you combine this with blown in insulation to increase r value or do you sometime use it stand alone?
Just started carrying it, what would be a valid retail price for product?
Kenny K is offline
Old 12-21-2009, 09:43 PM   #35
buddy110's Avatar
We do both or one of the two depending on the situation. In a home drenched by the sun I'll use eshield.
I like to install this on the roof rafters. Do that and the attic will be 25 degrees cooler in the summer
buddy110 is offline
The Following User Says Thank You to buddy110 For This Useful Post:
Tom Struble (12-21-2009)
Old 12-22-2009, 03:54 PM   #36
Windows Plus
Kenny K's Avatar
That makes sense, It depends on the application if you are considering both e shield and insulation.
Kenny K is offline
Old 12-22-2009, 03:56 PM   #37
buddy110's Avatar
You have top be careful with laying it over top of fiberglass or paper (cellulose). That can cause condensation to collect on the underside in winter. That's not a good thing
buddy110 is offline
Old 12-22-2009, 03:58 PM   #38
Windows Plus
Kenny K's Avatar
That is a great explanation. It makes us window guys understand a little better I am just a beginner, Hey did you guys here about the cash for caulkers? That sounds like a great opportunity.
Kenny K is offline
Old 12-22-2009, 04:00 PM   #39
Windows Plus
Kenny K's Avatar
so, you need some sort of dead air space? would you use a diifferent type of insulation? so you blow in with machines of bat type. I know some contractors use this atticcat/
Kenny K is offline
Old 12-22-2009, 04:03 PM   #40
buddy110's Avatar
You can use attic cat or anyhing you want. It's just a bad idea to lay this stuff over top of it.
buddy110 is offline
Frost inside the attic? SOSSW Roofing 22 04-03-2009 08:26 AM
Need some expert advice for attic insulation bean Insulation 1 03-12-2009 03:42 PM
review attic insulation webpage please Grumpy Insulation 4 02-07-2009 10:26 AM
Recessed light cans, heat and attic insulation im4snow Insulation 3 09-30-2008 03:02 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
