Trade: Rennovation
Attic Insulation
Which one should I use Kraft faced or unfaced for attic insulation. Looking to use 24" R-30.
From what I have heard in the past a moisture barrier isn't necessary for the attic. So before I go out and buy a ton of insulation, I wanted to as you insulation pros on here. Thanks |
Re: Attic Insulation
REN, please complete your profile, tell us a little about your business, and how long you have been in construction, thanks GMOD
#3 | |
Trade: Rennovation
Re: Attic InsulationQuote:
Mostly did some rennovation jobs with flooring and tiling. |
#4 | |
Thanks , REN
Trade: Insulation contractor
Unfaced if there is exiting. Is it a truss ceilin hauling bags though that is difficult I won't even price batts only blow
Trade: Rennovation
Right now it's bare. I was told that it's it's kraft faced to lay if facing down but unfaced was better.
Does it make any difference? Do I still have to put a moisture barrier like 6 mil plastic to cover the ceiling prior to sheetrocking? |
Trade: Roofing
Hi,
Use faced insulation. |
Trade: Rennovation
Re: Attic Insulation |
Chief Toilet Mover
Trade: Bathroom Remodeling
Why wouldn't you blow insulation instead? Batts are pretty much useless in my opinion.
If you are going to use batts put the Kraft side down. Vapor barrier goes on the warm surface. But don't sandwich any kraft paper between layers, peal those off after the 1st layer. Or just blow loose fill insulation in. Last edited by Mike Finley; 11-04-2009 at 10:48 PM. |
I like Green things
I heard Rock Wool is all the rage.
Vermiculite is starting to catch on though.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
#11 | |
Trade: Rennovation
I was deciding versus this : http://www.lowes.com/lowes/lkn?actio...344&lpage=none OR http://www.lowes.com/lowes/lkn?actio...243&lpage=none Problem is that no lowes close to me seem to carry the unfaced R-30 which is very strange. I have to special order them. Since I keep hearing from some local insulation guys that unfaced is preferred for attics and that the unfaced batts cost about $9 less per package. That why I asked what makes sense faced or unfaced. |
Trade: contractor
The only advantage friction fit batts have over blown in cellulose is batts can be installed from below prior to drywall. You can insulate that way in cold weather then put up a VB and get some heat in the building to drywall. Last I checked blown in cellulose installed was cheaper than equivelent R value batts installed. I recommend an R38 in the ceiling.
#13 | |
Trade: Rennovation
I have a lot of R-19 unfaced left over that I was thinking of putting on top of the R-30. That would give me about 18 inches total. But the question is whether i sohuld g faced or unfaced on the R-30. |
#14 | |
Get the 24" friction fit. Your climate is similar to mine. A vapor barrier isn't necessary in a ventilated attic.
#15 | |
Trade: contractor
#16 | |
It may be required there, it isn't here. The idea is water vapor passes through the ceiling and is vented from the attic.
Trade: contractor
OH! you meant REQUIRED...I thought you meant necessary.
The problem with that theory is the means by which water vapor passes through the ceiling...the majority of which is carried with warm air. This means heat loss. Do you like heat loss? I don't like it. It's expensive to heat air. I want to keep it in the space below the ceiling rather than vent it out of the roof attic into the atmosphere. I know you agree. Last edited by mics_54; 11-05-2009 at 11:55 AM. |
#18 | |
Not here. Water vapor travels from the higher concentration to the lower concentration. It does not require heat transfer. There is no difference in heat loss whether there is R-38 with vapor retardant, or R-38 with out vapor retardant.
#19 | ||
Chief Toilet Mover
Is this for your house or a customer. I was under the impression this was a job you were doing for somebody. I thought you were going to do the work? Quote:
Faced insulation agaist the drywall ceiling. The craft paper goes against the warm surface. If you put more on top of the first layer, it goes on at 90 degrees to the bottom layer and make sure you don't have any paper sandwiched between them. If I have to tell this all again I'm going to send you a bill. ![]() Hey, has anybody told you, blown in would be a lot better way to go? |
#20 | |
Trade: Rennovation
| Frost inside the attic? | SOSSW | Roofing | 22 | 04-03-2009 08:26 AM |
| Need some expert advice for attic insulation | bean | Insulation | 1 | 03-12-2009 03:42 PM |
| review attic insulation webpage please | Grumpy | Insulation | 4 | 02-07-2009 10:26 AM |
| Recessed light cans, heat and attic insulation | im4snow | Insulation | 3 | 09-30-2008 03:02 PM |
| Radiant Barrier Fact Sheet | Ed the Roofer | Roofing | 0 | 02-09-2008 08:57 PM |
