Well that's just it, treat it like you would vinyl except keep in mind that it will bend if pulled to hard. You need to loosen the panel above to hold out while you nail your replacement and then zip the lock closed. I tapped the lock with the butt of my hammer to make sure it locked in and counter any accidental bending.
In theory you're not supposed to be able to without tearing down everything above the repair. In practice you have to exercise caution, take your time and be careful. Clear as mud, right?
I never photoed a repair like this, maybe some one else has and will chime in for you.
Good Luck
OK, rant if you must. For the love of Pete, use paragraphs and spell check.
