1st Floor Ceiling
Old 10-14-2010, 05:58 PM   #1
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Rewards Points: 1,014
Send a message via Yahoo to Bill
1st Floor Ceiling
I have a 2 story house. We are downsizing it and do not want to use the 2nd floor as living space because we dont need it for one, for 2 it will reduce my tax if the 2nd floor is storage. I do not want to tear it off either as if I sell it, the new owners will have the option of having the additional space if they want it. We tore out everything on the first floor and re insulated the floors and walls, installed new sheet rock. Now that I have decided not to use the upstairs I want to be sure of the insulation. It is my understanding that the ceiling needs to be R38 when the area above it is not going to be conditioned. My ceiling joists are 8-1/4" now (Its full cut lumber, the house is about 100 years old) I looked around and figured R38 is 12" thick. So, I need to add at least 3-1/2" more insulation. Now I thought of 2 ways, one is to install 2x4 90 degrees to the existing joists and fill it in with the green blown in insulation, or the batt insulation. Then I can lay my plywood down and nail it. So, would the existing 8-1/4 insulation be fine, or should I add 3-1/2 more? And which insulation to use, the green blown in on top of fiberglass, batt over batt? Or pull the batt up and install blown in first and top off with fiberglass batt?
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 10-14-2010, 08:41 PM   #2
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
Re: 1st Floor Ceiling
Blown in doesn't offer the same value for its thickness as batts.
So you would probably need more than 3 inches of blown in to make-up the same r-value.
Brett Hocking
Eagle Eye Construction/Aspen Custom Cabinets
Buffalo, WY
bhock is offline
The Following User Says Thank You to bhock For This Useful Post:
Bill (10-14-2010)
Old 10-14-2010, 09:23 PM   #3
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
Can you explain the situation a little more......Is there living space upstairs that you're closing off?
I'm guessing here, but maybe just lay r-19 bats down over the existing floor and choose a room or two to build a temporary platform for storage......I'm curious.....
WNYcarpenter is offline
Old 10-14-2010, 09:25 PM   #4
Plumber / Carpenter
Bill's Avatar
2nd line. I am not using the 2nd floor as a living space any more
Bill is offline
Old 10-14-2010, 09:31 PM   #5
wannabe
Trade: carpentry
What is up there.....is it open floor joists........is it finished?
Old 10-14-2010, 09:40 PM   #6
Plumber / Carpenter
Bill's Avatar
Is not finished at all, we gutted everything, floors, walls, ceiling.
Bill is offline
The Following User Says Thank You to Bill For This Useful Post:
WNYcarpenter (10-14-2010)
Old 10-14-2010, 09:53 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,100
What?
First, IMO R38 is overkill for VA, but whatever.
Standard insulation in the first-floor ceiling plus attic/roof insulation won't add up to R38?
I'm not even going to try to guess why you would gut the upstairs, using it or not.
Tinstaafl is online now
Old 10-14-2010, 09:56 PM   #8
wannabe
Trade: carpentry
I would insulate the the 8 1/4" with the appropriate bats, then deck the 2nd floor with 3/4" like normal. Then lay r-19 bats over the floor. Or, just deck what you need for storage if there's a vapor issue with decking the entire floor.
If you think you may sell, IMO you want the availability as simple as possible. I wouldn't build up the floor, unless it was temporary.
Old 10-14-2010, 10:02 PM   #9
Full Service Renovations
MAD Renovations's Avatar
Am I unsterstanding you right...... You gutted your second floor down to the joists and studs to save a few bucks on your property taxes.
Is it just me or this the strangest stuff you have heard!!!! Sorry man this is just some wierd sh*t is all!!
MAD Renovations is offline
Old 10-14-2010, 10:04 PM   #10
Plumber / Carpenter
Bill's Avatar
Originally Posted by Tinstaafl View Post
What?
The reason fo gutting it was because there was 4 bedrooms up there, we were going to make it into 1 master suite. 26' x 26'. Also the house was balloon framed, the studs vary from 4" to 4-3/4" in depth, the walls were way out of plumb, they were wavy due to the inconstancy of the stud thickness, so we planed on snapping chalk lines and using 2x3 to build a new wall inside of the old one. But then as I said, we decided not to go that rout. We want to keep everything on one floor. My wifes dog is 7 years old and we figured its going to get rough on her to get up and down. Also its less area to heat and cool
Bill is offline
Old 10-14-2010, 10:06 PM   #11
Plumber / Carpenter
Bill's Avatar
My house is 26x26 2 story with a 26 x 26 single story added on the back. I had 16 people living here at that time. Now its just me and my wife, so why do I need to use that space for?
Bill is offline
Old 10-15-2010, 07:43 AM   #12
Sar-Con's Avatar
Trade: Civil Construction, Excavation, Concrete + Forming
Rewards Points: 504
I'm getting worried. I see the guns and wonder where the 16 people went.
Sar-Con is offline
Old 10-15-2010, 11:56 PM   #13
ASInsulation's Avatar
Trade: Insulation and Weatherization
Rewards Points: 220
i dunno why everybody is so interested in what your doing with your own home...lol...but here is the best solution for your question that i could come up with...
if you have all the floors gutted, i would say use two part foam insulation to airseal the entire attic plane...that make a big difference in the effectiveness of your insulation...then its up to you...if you intend to leave everything unfloored, use r-30 fiberglass which should achieve you an r-37, with all penetrations, seams, and wall tops airsealed...very effecient...or, you could put plywood down and denspack between the foam and the plywood...this will get you your best insulation value, plus be a great sound reducer if you ever did decide to use the second floor again, or as a resale value....
ASInsulation is offline
The Following User Says Thank You to ASInsulation For This Useful Post:
Bill (10-16-2010)
