Zinsser 123
Old 11-23-2006, 09:39 PM   #1
wwc
Shoalsfugro's Avatar
Trade: Remodeling and Restoration
Thumbs down
Zinsser 123
Has any one had problem lately after using zinsser 123 it dries in about a hour and has a lite gloss. I have three houses I primed cabinets and doors. All three have different top coats BM,Glidden,SW. All top coats are peeling in sheets in less than six weeks? Any input? I spoke with a paint supplier they say they have heard this from others, have you had this problem?
Best,
Mike
Louisiana
Shoalsfugro is offline
Old 11-23-2006, 10:59 PM   #2
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Re: Zinsser 123
the primer is not the issue
Rich
Richard is offline
Old 11-23-2006, 11:26 PM   #3
metomeya's Avatar
Re: Zinsser 123
Never had a problem with zinsser.
If it had a gloss to it, it should have told to right away there was something wrong.
metomeya is offline
Old 11-23-2006, 11:37 PM   #4
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Zinsser 123
Do you mean the finish coats are peeling away from the primer?
Or the primer is peeling off too?
ProWallGuy is offline
Old 11-23-2006, 11:47 PM   #5
House Painters Reading PA
4thGeneration's Avatar
Re: Zinsser 123
Best,
Mike
Louisiana
Was the surface clean, dry and dull before primers were applied?
When you cleaned it what did you use? I like liquid TSP to clean.
I tend to shy away from quick dry primers.
4thGeneration is offline
Old 11-23-2006, 11:48 PM   #6
rws's Avatar
Trade: paint contractor
Send a message via AIM to rws
Re: Zinsser 123
How long did you wait before finish coating? New cabinets or repaints?If repaints did you use tsp when washing?
rws is offline
Old 11-24-2006, 12:04 AM   #7
contractor
cmwacasey's Avatar
Trade: carpentry plumbing electric
Re: Zinsser 123
Have you had success with this primer ,prior to these last three jobs.
cmwacasey is offline
Old 11-24-2006, 06:53 AM   #8
...jammin
slickshift's Avatar
Trade: Rock Disciple
Re: Zinsser 123
I would find it difficult to believe it's the primer
Signature Quote
slickshift is offline
Old 11-24-2006, 08:38 AM   #9
My custom title
Brushslingers's Avatar
Re: Zinsser 123
What kind of 123? Oil, latex or alcohol? Sounds like you used Latex and an Oil topcoat, breaking the number one rule of all time.... Latex over oil, NEVER oil over latex.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 11-24-2006, 10:11 AM   #10
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
Re: Zinsser 123
Huh????
chris n is offline
Old 11-24-2006, 10:19 AM   #11
My custom title
Re: Zinsser 123
It's a rule of thumb, latex is water, and sweats... if you oil over latex, whatever is under it will rot/rust three times faster. You can however, put oil under latex fine.
Benn
Old 11-24-2006, 06:21 PM   #12
AFI's Avatar
Trade: Paint Contractor
Re: Zinsser 123
Yeah the same happened to me with my girlfriend. I don't know what is best if she over me or me over her. By the way she is like latex... wet
AFI is offline
Old 11-24-2006, 08:38 PM   #13
wwc
Re: Zinsser 123
Top coat is peeling from primer, Latex used for zinsser 123 and topcoat. the primer dries so quick about one hour and hard, after it dries it has lite sheen. I spoke with a supplier today and he stated there is a problem with the 123 with bonding between top and primer. Thanks for all the input. Back to fresh start for primer.
Old 11-24-2006, 08:44 PM   #14
contractor
cmwacasey's Avatar
Re: Zinsser 123
so shoals, what is the problem.Are you suggesting we should quit using this product.
Old 11-24-2006, 09:43 PM   #15
metomeya's Avatar
Re: Zinsser 123
Ya, like i said sounds like you just got a bad batch.
metomeya is offline
Old 11-24-2006, 10:18 PM   #16
ProWallGuy's Avatar
Re: Zinsser 123
Is this new construction?
Could a fine layer of dust have settled between priming/painting?
Old 11-24-2006, 10:24 PM   #17
LennyV-NHSNOLA's Avatar
Trade: Residential Renovations/Remodeling
Re: Zinsser 123
AFI,
The same thing applies. No oil on the latex or you may end up with a bunch of little zinsser's running around in 9 months.
LennyV-NHSNOLA is offline
Old 11-25-2006, 05:23 AM   #18
rws's Avatar
Re: Zinsser 123
I asked about tsp because Zinsser says to not use it if you are using bin or 123.
rws is offline
Old 11-25-2006, 10:05 AM   #19
Mike Danahy
Danahy's Avatar
Trade: Signature Painter
Re: Zinsser 123
Not sure I would've used anything latex on cabinets, but that's cause I'm an oil guy for anything other than walls or exteriors. The only time I use 123 is when I'm painting walls that have too much texture. 123 has excellent bridging capabilities. Because of the bridging qualities I find that it lacks the sanding capabilities...
How long did you wait for the 123 to dry? Perhaps the 123 was still releasing its moisture which made for a crappy bond between top coats. Even if something says 1 hr dry, I try to wait a day between coats...
imo
Danahy is offline
Kilz or Zinsser? Richard Painting & Finish Work 41 11-30-2007 08:58 PM
SWP buys MAB?? & Zinsser GoodPainter Painting & Finish Work 17 04-17-2007 01:50 AM
2 coats of primer on ceiling rather than paint? Zeebo Painting & Finish Work 20 12-25-2006 01:05 PM
Zinsser exterior paint Miniroller Painting & Finish Work 3 09-23-2006 07:12 PM
What's everyone think about Zinsser Primer?? Sellncars Painting & Finish Work 7 08-03-2006 12:10 AM
