Trade: painter
Wood Paneling Question Guys
In My Old House There Is Wood Paneling Everywhere. My First Question Is: Can U Texture The Paneling Using Joint Compound If U Prime It First? If I Can Then Should I Fill In The Grooves And Let Them Dry Before I Texture? Also In One Room There Is Sheetrock On The 2 Outside Walls And Wood Paneling On The Other 2 Walls. If Can Texture It, Will The Paneling Match The Sheetrock Good. Thanks.
Trade: Painter
Re: Wood Paneling Question Guys
Hope you don't mind me adding one in to this subject... If you're going to primer over the wood paneling, what's the best primer to use?
Trade: Painter
In my basement, the paneling moved enough between studs when you would push on it that I would be concerned with the drywall mud popping off of the paneling if some leaned against it.
For primer, I recommend something like Zinnser coverstain, sand the walls first. A good waterborne will stick, but there might be some bleed through with the waterborne primer. |
Trade: painter
yea, one of my friends who is a painter told me i might have problems with the mud popping out. My house is about 50 or 60 years old. i beleive the paneling is nailed onto toungue and groove and not studs. Is there anything else i could use that would stick to it? I really don't want to have to sheetrock the rest of it right now. How about the texture addive u add to paint? I would really like to hide the grooves in the paneling so it would match the sheetrock. Would the fast dry mud stick better? Just found this cool website yesterday.
Bondo will stick better than mud. Use an oil or shellac based primer.
It seems to me to be about the same amount of work as rocking.
Trade: Handyman Services
I've got a room in my house with knockdown over paneling.......use a good oil based primer to lock in anything in the paneling, then just mud or whatever over it. This room has been like this for 8 yrs, painted, and then re-painted this past year....no probs at all!! Hope this helps...
Educated Applicator
I agree about just putting up new rock. Have to be easier and maybe cheaper.
Trade: Painter
I have had excellent results using XIM UMA primer. That stuff really grips. Then I usually finish coat the paneling with BM dulamel eggshell 2 coats. Did this at a few customers houses (usually in basements) and my own house. I really wanted to joint compound the grooves to make the paneling match the sheetrock but thought it would give me too many problems in the future so we live with it the way it is and i cant say I even mind it much.
yep |
Mike Danahy
Trade: Signature Painter
Could you just flip the panelling over, and start from there?
Trade: Painter
Depends on how thick the paneling is and how it's attached. If it's thin paneling and not solidly attached to evenly spaced studs, it will move around cracking the compound on the joints.
My preference would be to re-rock. I've never liked the outcome of painted paneling unless you skim every square inch. PS. Although you can use compounds and bondo, you're taking a chance. Sheetrock has to be taped on all joints, the same would apply to paneling. |
Trade: painter
If I Do Use Mud, I Am Planning To Screw It Down Good. I Also Have The 12" Ceiling Tiles Throughout The House. Has Anybody Ever Textured This Type.
Trade: Remodeling contractor
Bigbrew. Go to your paint supply store (Ben Moore or Sherw Wiilliams and ask for the wallpaper that's made to go over paneling. You put this stuff on and it spans the voids and you're ready to paint !!! HD or Lowe's will not have this product.
Back in Maine Dubbin' Around Doin' good stuff ...... |
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| Question about bidding vinyl wallcovering | kanadaeh | Painting & Finish Work | 9 | 02-19-2009 05:29 PM |
| Does any Wood Floor guys use Scheduling program on their PC's? | brianosaur | Flooring | 3 | 03-11-2007 12:39 AM |
| Question for Hardwood and Carpet Guys.... | UpIACrete | Flooring | 2 | 02-21-2007 01:39 PM |
| Question about floating wood flooring | zoner11 | Flooring | 10 | 01-17-2006 05:04 PM |
