Wisc's Getting Cold Fast
Old 10-09-2006, 08:25 AM   #1
Suck it up, or shut up
rservices's Avatar
3/4 the way thru painting my house, and the temps droping. mid 50's all week
Im using SW super paint, should I wait for warmer weather or just go for it
rservices is offline
Old 10-09-2006, 09:22 AM   #2
AFI's Avatar
Trade: Paint Contractor
Re: Wisc's Getting Cold Fast
You can use Super Paint up to low 36 F but I'm haven't any Experience on cold weather.
AFI is offline
Old 10-09-2006, 12:13 PM   #3
chuckdec's Avatar
[QUOTE=rservices;140995]3/4 the way thru painting my house, and the temps droping. mid 50's all week
Im using SW super paint, should I wait for warmer weather or just go for it[/QUOTE
We work out of Mass and have seen some spot frost in the suburbs in the past 2-3 weeks and generally stop all outdoor coatings by October 1st.
Some manufacturers carry a "Low Temp" product with limited sheens.
Your best bet would be to contact the manufacturer and pop the question to them, (tech support, or if you’re a contractor, call your rep).
Curing process takes up to 21 days and you need to watch the overnight lows.
Think of it as a room full of basketballs, during the curing process visualize these basketballs spreading and expanding to form one uniform film, without the proper drying conditions the curing process will suffer.
Good Luck,
Charlie
chuckdec is offline
Old 10-09-2006, 01:24 PM   #4
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
Colder temperatures will generally extend your dry times. It says right on the can of Super Paint:
Dry Time
35 - 45 degrees - 2 hours to touch and 24 hours to recoat
45+ degrees - 1 hour to touch and 4 hours to recoat
The primary reason you need temperatures to be above 50 degrees (24 hours before and after) when you paint is to draw the moisture out of the substrate. This only matters with porous substrates i/e wood. Not so much with aluminum siding.
If you used a moisture meter before you primed and it showed moisture levels below 15%, you will be OK to use a low temp topcoat, down to 36 degrees.
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 10-09-2006, 04:51 PM   #5
Professional Painter
Richard's Avatar
Trade: Owner/Operator
You're fine. Most exterior paint these days is 35 and above. Get that house done!
ps- how do you know 'warmer' weather will come?
Rich
Richard is offline
Old 10-09-2006, 06:52 PM   #6
rservices's Avatar
thanks for the post,
I was able to get one whole side done, their calling for snow this weekend
Old 10-09-2006, 06:57 PM   #7
Richard's Avatar
Wow...snow....almost time for you to hibernate indoors soon then!
Rich
Richard is offline
Old 10-09-2006, 10:29 PM   #8
Pro Painter
AAPaint's Avatar
Yup, with super paint down to 35F we can paint exteriors pretty much all year long with no issues. Luckily it seems we get more interior work naturally during the cold months because people are inside staring at their walls.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 10-10-2006, 01:41 AM   #9
Joewho's Avatar
Trade: Painter
Don't forget that with Wisconsin's lower temperatures comes lower humidity. It may be the saving factor.
Joewho is offline
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
Cutting Cold Shingles Spencer Roofing 38 01-31-2006 09:50 AM
Hot and Cold Mixing trudny Plumbing 1 01-12-2006 03:55 PM
calcium and lime in only cold side one bathroom only jaimester Plumbing 4 12-30-2005 08:03 AM
No Cold Water streborn Plumbing 2 03-17-2004 06:06 AM
