Why Is There Streak Marks??
Old 06-16-2006, 08:46 PM   #1
AHS's Avatar
Trade: roofing & Painting
How do you get a nice smooth finish when painting a wall. I don't have problems with flat paint but when I use satin or semi gloss I run into this problem. After the paint dries I can see roller marks. I use sherwin williams super paint.
Will sanding between coats help?
AHS is offline
Old 06-16-2006, 08:51 PM   #2
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
Re: Why Is There Streak Marks??
Yes it will. Also try not to put to much pressure on the roller while you paint. Light even pressure is the best.
You could also try the paint additive Floetrol, made by the flood company. It helps a lot with flow out and leveling. They advertise a spray like finish with brush and roll.
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 06-16-2006, 08:54 PM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
Three biggest causes of roller marks:
1) Cheap Paint
2) Cheap roller sleeves
3) Poor technique
Any one of the three and you're a good candidate for marks
Now I've never used Super Paint, but the SWP products I have used have been pretty good
What sleeve are you using? What nap?
Should be at least a top quality poly min. 1/2"
I'd recommend at least a 50/50 wool/poly
Are you trying to squish out all the paint from the sleeve?
A quality thick nap sleeve and you should be laying the paint down rather than squishing it out
Signature Quote
slickshift is offline
Old 06-16-2006, 09:51 PM   #4
Pro Painter
AAPaint's Avatar
I'm a frequent user of superpaint, and I never have troubles like that. Superpaint sets up very QUICK! If you let it sit any amount of time and touch it again...toast. Takes speed and skill to do a 6 panel door without streaking. As for walls, if you're rolling and seeing tracks it's most definitely a technique issue.
Very light pressure, good sleeves, etc like slick and humble said is what you need. Try moving the roller quick enough when rolling that it can flare open. Don't depress the roller, use lots of paint and light pressure moving quickly. If you've ever used lambswool you would understand this better. When you're rolling a wall, always keep a slight pressure on the leading edge of the roller, and the softer trailing edge will erase any tracks you might make.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 06-16-2006, 11:34 PM   #5
Just 'Finishing' Up...
erik edlund's Avatar
Hey, Slick, AAapaint
Good on ya, mates, good advice- lay it down, smooth it out, watch your technique, work it...
Kind regards,
Erik D. Edlund
erik edlund is offline
Old 06-17-2006, 01:42 AM   #6
General Contractor
jensenconstruction's Avatar
Trade: General Contracting and Painting
you can also have these problems if your roller is to dry.
jensenconstruction is offline
Old 06-17-2006, 05:38 AM   #7
KellyPainting's Avatar
Also remember that with anything other than flat always roll wet to wet.
roll from top of wall to the bottom of wall then across unlike me who does the top half of the wall across then the bottom across.
KellyPainting is offline
Old 06-17-2006, 04:18 PM   #8
AHS's Avatar
Thanks for the pointers. I think my problem is pushing to hard on the roller & not having enough paint on it.
I've never painted wet on wet before. That seems more like one thick coat to me.
AHS is offline
Old 06-17-2006, 10:11 PM   #9
lornmastro's Avatar
Trade: interior paint contractor and window treatment workroom
ok this might just be the answer i am looking for...i usually roll the top 1/2 of the wall then the bottom 1/2 of the wall and i can see where i have overlapped the top 1/2 and the bottom 1/2....this is especially a problem when i paint a 2 story walls and its driving me crazy...i'm using purdy 1/2 dove rollers and usually ben.moore regal eggshell...is this what you fellas are talking about when you say roller marks???and if it is i think i'm squishing the paint out instead of rolling it and need to roll from top to bottom..esp. with dark colors right???.whats flare open mean???
lornmastro is offline
Old 06-18-2006, 01:14 AM   #10
Teetorbilt's Avatar
The worst offender is trying to 'stretch' the paint. If you're trying to get the 600 sq,ft. per gal. that the can label says, you gonna have problems. FloTrol is good, ratchet up your roller and apply liberally.
The cost of paint is nothing compared to the price of labor.
Albert Einstein
Teetorbilt is offline
Old 06-18-2006, 07:01 PM   #11
lornmastro's Avatar
thanks for the reply..flotrol.....how much do you put in the can and do you do it on the job or do they do that at the paint store??and again what does flare open mean??
Old 06-18-2006, 07:21 PM   #12
Custom Builder
Glasshousebltr's Avatar
What do ya call it when a handcuffed naked fella wipes him bumb on the sidewalk before being stuffed in the squad car?
Streak marks.
Bob
Bob
Glasshousebltr is offline
Old 06-18-2006, 09:16 PM   #13
hack_houslege's Avatar
"what does flare open mean??"
I've never heard the term "flare open", but i would say it describes the fluffing action wall paint has on a natural roller sleeve when the thickness of the spread material and its relative wetness and rolling pressure are all in harmony. The sleeve and paint will produce a characteristic crackling sound as the paint pulls at the sleeve fibers, keeping the nap of the roller workable. No crackling sound means you've started to dry roll which will flatten the rollers nap- reducing the sleeves ability to absorb paint on subsequent dunks and producing poor stippling on your walls.
hack_houslege is offline
Old 06-18-2006, 09:29 PM   #14
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Someone here asked about doing 2-story walls in a sheen.
We roll a stripe or two on the top half, then roll a stripe or two on the lower half. Then back up to the top, then to the bottom. After 3 or 4 of these, go back and backroll from the middle of the top section to the middle of the bottom section. This should effectively blend in the two seperately rolled areas (top to bottom). Plus, the middle of the wall is the first part that hits your eye. If there is a transition to be seen on the wall, 2/3 of the way up, or 2/3 of the way down is where I would want it. Lower or higher than where your eye travels automatically. Does this make sense? I had a couple crown n cokes today.
ProWallGuy is offline
Old 06-18-2006, 09:44 PM   #15
rws's Avatar
Trade: paint contractor
Send a message via AIM to rws
A much easier product for you to work with if you have to use SW is Cashmire.Add some flotrol use a 3/8th white dove and you may have a sprayed like finish with 0 roller pattern.The eggshells will look better after a few days drying.
rws is offline
Old 06-19-2006, 12:09 AM   #16
Teetorbilt's Avatar
You still have to know how to apply paint. HGTV is a ruse!
Albert Einstein
Old 06-21-2006, 10:05 PM   #17
lornmastro's Avatar
pro guy...ok if i get this correctly you do roll the top 1/4 of a wall then 2/4th of the wall 3/4 of the wall 4/4 of the wall(or bottom of the wall) you do this 2 x or 2 coats of paint then you back roll the 2/3 top of the wall then the 1/3 of the wall(as long as the 2/3 is not visually a bad spot) ...i hope your not saying that you have to do 3/4 coats of paint???
Help me with boot marks camden09 Flooring 4 07-23-2007 02:50 AM
Swirl marks left behind by rotary buffer seen in stain Grainywood Flooring 3 12-06-2006 10:48 AM
prime marks on wall lornmastro Painting & Finish Work 37 11-12-2006 03:12 PM
removed border with dif and left streak marks lornmastro Painting & Finish Work 5 08-25-2006 06:21 PM
Roller marks in dark paint. cutnroller Painting & Finish Work 10 08-03-2006 11:09 PM
