Why Is Latex Paint Peeling??
Old 12-15-2005, 06:43 PM   #21
Zeebo's Avatar
Trade: Painter
Re: Why Is Latex Paint Peeling??
Thanks for the info. I have used the Peel Stop from Zinnser and have found it effective with peeling. Goes on clear and a gallon will take you a long way. It's probably similar to Gardz.
Zeebo
Zeebo is offline
Old 05-14-2009, 09:51 AM   #22
Paul Painter's Avatar
Trade: Historical restorations painter/plaster
Hey..this is great,some very good ideas and talk!! I have run into same things here in Canada.I usually use a good quality high hide oil.I found that latex has a reaction with old coatings also..sometimes in bathrooms I tell customer(if no fan present) that they cant use shower for 2 or 3 days before I come so moisture doesnt become a factor,so they use the bath only or another shower in the house..then I use my moisture meter to check condition..oil drives moisture out..I will roll oil first and leave cutting in for last..the moisture can escape around the edges prior to cutting in..seems to work this way..havent had a problem in 15 years of doing it this way...
Paul Painter is offline
Old 05-16-2009, 12:00 AM   #23
sparehair's Avatar
Trade: Painting, flooring
Ok, I'm a little skeptical of the water release at the edges theory but I'm sure the permeability rating of most modern interior paints is pretty high. The other day a guy was saying that lead paint would seal in linseed oil in glazing. Does anyone have any idea what the permeability traits of older paints were? Probably alot tighter I would imagine.
sparehair is offline
Old 05-17-2009, 10:41 AM   #24
DRC's Avatar
Trade: painting
Originally Posted by Zeebo View Post
What I am also noticing is that the paint is blistering in areas that had been patched...but the patch work had been painted over by the previous owner. Maybe no primer was used??
Zeebo
So it's what everyone has been saying from the start. Dust under the paint. Not yours but the original paint over the patches. Changing which paint you use will not make the problem go away. You need to remove all of the old paint that is failing. Prime the patches. Skim coat it. prime it again. Then apply finish coats.
DRC is offline
Old 05-28-2009, 07:59 AM   #25
Hey Sparehair...it seems to work out this way..I figure the moisture is migrating outward this way repelled by the oil looking for a place to leave.Its working so this is what I do,forcing moisture to the edges,again it could have no effect and you can be sceptical..moisture could still be there and finds another way out,good point!! As for the glazing,I have always used oil primer over top but not right off..I let it sit for weeks then go back,I let putty dry for a while or the brush will move it when its fresh..what do you do?....Paul
Bathroom Paint Problem - Strange Peeling firemike Painting & Finish Work 23 09-27-2007 07:53 PM
SW Latex Paint taking long to dry plazaman Painting & Finish Work 9 08-10-2007 08:20 PM
Determining if latex or oil base paint gary lee Painting & Finish Work 6 07-31-2007 01:02 AM
Peeling Latex on Orlando Deck - Proper Fix? brainswell Painting & Finish Work 21 11-17-2006 10:05 AM
