Old 07-20-2006, 10:21 PM   #1
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
What would the pros do?
I'm painting all the trim and most doors in an upcoming job. It's all oil now (2 coats) and slightly yellowed after just 5 years. I like oil but was wondering if it might be a good idea to sand, prime, and switch to latex. More labor involved but I want to do the right thing. Oil or latex?
ron schenker is offline   Reply With Quote
Old 07-21-2006, 12:33 AM   #2
Teetorbilt's Avatar
How old is the home? If it's a classic, I'd stay with oil. You can just scuff with some 3M pads and 'get'er done'.
I'm an old guy. Like the smell of oil based products. I'm not in a panic to get it done yesterday. I do like to do things right and I was taught that oil goes on wood. I don't see any waterbased paints that approach it for durability.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 07-21-2006, 05:15 AM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
I like working with oil
It's more durable
It lasts 3X as long (at least in this environment)
Trim and doors?
Oil...no question
Signature Quote
slickshift is offline   Reply With Quote
Old 07-21-2006, 06:24 AM   #4
Teetor: the house is 12 years old and this will be it's second paint job (since the original)
Old 07-21-2006, 06:45 AM   #5
Jonesey's Avatar
Trade: Painting and Finishing
Oil would be best. Looks better, and it's more durable. Don't forget to TSP the kitchen and bathrooms before you sand. All that grease and hair-spray inhibits adhesion.
Steve Jones
steve@jonespaintingonline.com
Jones Painting Feel the difference service makes
Jonesey is offline   Reply With Quote
Old 07-21-2006, 02:48 PM   #6
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
If it's got oil, your best solution is another oil product. Same if it had latex, stay with latex simply because latex is easier on the health and the environment.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline   Reply With Quote
Old 07-22-2006, 03:21 PM   #7
Trade: painter
Porter Paints makes a non-yellowing oil product called Glyptex.
Sean Kennedy
St. Louis Painting Contractor
Kennedy Painting LLC
KENNEDY is offline   Reply With Quote
Old 07-23-2006, 06:58 PM   #8
SgtBaldy's Avatar
Not much help to you because it is a florida manufacturer but this stuff is the reason I swithed to acrylics on a lot of interior trim.
http://www.scottpaint.com/files/435%...Semi-Gloss.pdf
Gets hard enough to sand the first coat and tips out to a beautiful finish. Not quite as mirror like as you can get with oil but the fact that it won't crack makes it a fair tradeoff imho.
Tampa Painters
SgtBaldy is offline   Reply With Quote
Old 07-27-2006, 11:09 PM   #9
My custom title
Brushslingers's Avatar
Porter acri-pro high gloss is just as hard, and mirror-like as oil. Tell ya what, i've been doing this for 30+ years, i'm tired of dying. Instead of dumping your used spirits in the area the driveway is going down or paying through the nose to get it dumped, check out new product lines.
Besides, this stuff they call oil based isn't real anyhow, they changed the formula's years ago and took all the good stuff off the market.
Whatever you go for though... prep prep and more prep, nothing looks good with a first graders prep work.
Brushslingers is offline   Reply With Quote
Old 07-27-2006, 11:18 PM   #10
Moderator
Double-A's Avatar
Unless you hang it on the refrigerator. Then it looks like art.
New York Times, July 20, 2006
Double-A is offline   Reply With Quote
Old 07-28-2006, 01:47 AM   #11
My custom title
Ha! Now that would be an interesting Faux, taking 1st graders art and making a mural on a wall.... hmmmm....
Need advise from the pro's KellyPainting Pressure Washing 4 08-20-2007 10:55 PM
Crawlspace ducting question for the pros ctbuilder HVAC 6 07-26-2007 08:14 PM
Self employed guy needs some advice from the Pros to keep things straight... Luny Landscaping 14 05-27-2007 11:38 AM
One for well system pro's. Teetorbilt Plumbing 5 12-18-2006 12:17 AM
Union Labor pros & cons cueitup02 Electrical 48 09-05-2006 06:01 PM
