What Wood Filler Would Work Best ?
Old 11-02-2010, 01:52 PM   #1
Crispy's Avatar
Trade: Drywall Finisher
Rewards Points: 75
Painting MDF with semi-gloss enamel , which filler would be best for this ?
Thanks ,
Chris
Crispy is offline
Old 11-05-2010, 10:44 AM   #2
BrushwrksPaint's Avatar
Re: What Wood Filler Would Work Best ?
I think the best wood filler/repair product is the epoxy stuff you get in a caulk tube set-up from most paint stores, I forget what it is called, just go into the local SW and ask about it.
Other than that I always have used Bondo
BrushwrksPaint is offline
Old 11-05-2010, 10:48 AM   #3
Professional Tradesman
GPI's Avatar
Trade: Painting-Wallcoverings-Drywall-Carpentry
Rewards Points: 250
Thanks ,
Chris
What exactly are you filling? Nail holes? Epoxy? Bondo? Seriously? Honest question here. If its nail holes, simple shrink free spackle would be fine, light sand for a flush finish.
GPI is offline
Old 11-05-2010, 11:09 AM   #4
deej's Avatar
Trade: painter
Also believe it or not. Depending on the color of what you spraying. Crayons wax works wonders also just make sure you do not dig it out when wiping off. It doesn't shrink
deej is offline
Old 11-05-2010, 11:25 AM   #5
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
for big patches such as repairing big gouges in old doors or electrical boxes that were in the baseboards, i use bondo
for small stuff i was using drydex but found it dries out and cracks. our painter turned me onto glazing compound, it doesnt dry out or shrink. and as long as oil based primer is used its mint
woodworkbykirk is offline
Old 11-05-2010, 08:06 PM   #6
briancreary's Avatar
Rewards Points: 75
I second the motion on Bondo. Stinks bad, but sands easy...wear a mask
briancreary is offline
Old 11-06-2010, 07:19 PM   #7
Andrew M.'s Avatar
Rewards Points: 150
Fixall works great ,inexpensive, no smell, has adhesive, water based so it penetrates and has wood fillers, even looks like it in color. Apply Tite bond II 50:50 dilutes w. h2o, over it as a bond/sealer after it drys if it is large patch. Bondo I have had less success with. as it does not penetrate as good, and has no wood products in it.
Andrew M. is offline
Old 11-06-2010, 07:40 PM   #8
semi-skilled laborer
ModernStyle's Avatar
Trade: Professional Painting
Rewards Points: 1,186
MDF is garbage, use an easy sand spackle or you might rip into the MDF while sanding
OwensboroPainting.com
ModernStyle is offline
The Following User Says Thank You to ModernStyle For This Useful Post:
moorewarner (08-29-2011)
Old 11-06-2010, 08:26 PM   #9
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,698
Only when cheap HO's put it up.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 11-06-2010, 09:54 PM   #10
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
...MDF is a great building material and there are places for it and places not for it. You have to know how and where to use it just like any other building products. If you really want to get into it, Pine blows on all aspects, it sucks at taking paint, moves a crap load and you look at it the wrong way and it dents/dings/splinters. MDF is superior to Pine in all those aspects, only place I won't use it is high humidty areas....
as far as I am concerned if you want something better then MDF you have to step up to at least Poplar.
TBFGhost is offline
The Following 3 Users Say Thank You to TBFGhost For This Useful Post:
moorewarner (08-29-2011), Remodelor (11-07-2010), WildWill (08-27-2011)
Old 11-07-2010, 09:53 PM   #11
Logistics
jackpauhl's Avatar
Trade: Painting, Product-Systems Integration
Sherwin Williams Shrink-Free, DAP Fast N Final, DAP CrackShot, or Elmers Wood Filler. All sands easy, all can be knifed on flats. Fast N Final and SW Shrink-Free are lightweight foam-like. DAP Crackshot and Elmers are more like thinner drywall mud.
[the right products, the right systems, the right place, the right time] jackpauhl.com
<facebook>|<flickr>|<twitter>|<youtube>
jackpauhl is offline
The Following User Says Thank You to jackpauhl For This Useful Post:
Old 11-07-2010, 09:57 PM   #12
Remodelor's Avatar
Trade: Bath Remodeling
Rewards Points: 250
I've had a lot of luck with Crackshot by DAP. Super easy to work with and sand spackling paste.
Remodelor is offline
The Following User Says Thank You to Remodelor For This Useful Post:
Old 11-07-2010, 10:04 PM   #13
Logistics
jackpauhl's Avatar
Yep. CrackShot is nice. I use all of them on a regular basis on MDF. CrackShot and Elmers are better for larger and deeper fills but they all work great for nail holes. I use my thumb to press in all of them on any rounded or profiled piece and I use a flexible 1.5" knife to press into holes on anything flat, the body of base etc.
General TIP: When using your thumb to fill, press in enough so it crowns a bit, then sand off when dry. DAP Fast N Final tends to stay the wettest the longest as many of you know MDF sucks up whatever you put on it. Shrink-Free tends to dry out quicker and needs more kneading and recycling back to the bucket to get more moist stuff.
Old 11-28-2010, 09:46 PM   #14
ltd's Avatar
Trade: painting
4 nail holes redy patch it nice and dense i use flexable putty knife or single edge razor blade fill hole then scrape clean prime paint this will be very good. if it needs to b perfect over fill and sand
ltd is offline
Old 08-27-2011, 06:24 PM   #15
Educated Applicator
MarvinWilleyJr's Avatar
Trade: Painting & Fine Finishes
Rewards Points: 286
We have used light weight spackle for years, but thinking of finding something else. For some reason latley the last few tubs we have got have been spoiled? or something. It doesn't sand worth a dam and almost seems to act like caulking when we try to sand it. Also looks gel like in the tub? Might just be some tubs the guy I work with has had in his truck a months in the florida summer weather.
A stupid man's report of what a clever man says is never accurate because he unconsciously translates what he hears into something he can understand.
MarvinWilleyJr is offline
Old 08-27-2011, 07:34 PM   #16
WildWill's Avatar
Rewards Points: 504
We've been using RediPatch on MDF as it's a bit harder to sand then the lightweight spackle. When using the lightweight it just seemed to be either shrinking back into the hole or we were having a hard time controlling the sanding.
WildWill is offline
Old 08-28-2011, 03:00 PM   #17
Educated Applicator
Rewards Points: 286
We put the light weight on thicker to factor in the shrinking of "the so called nonshrinking spackle" ..... Cause it is usually pretty easy to sand down. Put we always seem to have to touchup the spackle spots one time after we first coat, and kind of double checking... Because of either shrinkage, or those overlooked nail holes
Old 08-28-2011, 03:04 PM   #18
RhodesHardwood's Avatar
Trade: Hardwood Floors
Rewards Points: 594
I have to agree with the bondo. I just redid some cabinets and it worked well.
RhodesHardwood is offline
Old 08-29-2011, 03:39 PM   #19
MWAFSI's Avatar
Trade: remodeling and finish work
Sherwin williams makes a product called glazing putty, it comes in a toothpaste like tube and is a bondo type product. It sands easy and holds up well
MWAFSI is offline
The Following User Says Thank You to MWAFSI For This Useful Post:
Jaws (09-03-2011)
Old 08-29-2011, 04:32 PM   #20
Raawwwrrrr
blackbear's Avatar
Trade: finish carpentry
Rewards Points: 1,394
I like mh
blackbear is offline
Best wood for trailer shevles and work bench? ruskent Vehicles 30 03-15-2011 04:11 AM
Looking for work southern dutchess county NY "JJ" Help Wanted or Looking For Work 1 05-25-2010 01:03 PM
Any Plumbers looking for work in Boston, MA area? sadegs Help Wanted or Looking For Work 2 02-20-2009 06:45 PM
wood filler vs. caulk for trim fabiano Painting & Finish Work 13 07-29-2006 02:09 PM
i need work ! wood flooring installer woodfloors Help Wanted or Looking For Work 1 01-30-2006 07:12 PM
