What Sprayer Should I Get
Old 09-02-2009, 03:53 PM   #1
Tuck's Avatar
I am going to spray mostly cabinets. MDF, latex paint. I will use the sprayer to do some bigger jobs. Like a fence. Any indoor painting of walls trim ect. I sub out. I have looked at a HVLP, because of the fine finish work. Any input would be great.
Tuck is offline
Old 09-02-2009, 05:45 PM   #2
Workaholic's Avatar
Trade: Painting Contractor
Re: What Sprayer Should I Get
get an airless.
Sean
Workaholic is offline
Old 09-02-2009, 05:50 PM   #3
Smart phone? Scan me!
nEighter's Avatar
Trade: Painting/Framing/Drywall
graco 395
nEighter is offline
Old 09-03-2009, 10:13 AM   #4
Store Owner
NCPaint1's Avatar
Trade: Paint Store Owner
Originally Posted by nEighter View Post
graco 395
Close, 395 + Fine Finish tip's Or the XR-7 is a cheaper alternative, but wont spray heavy materials.
www.northcromwellpaint.com Benjamin Moore Paint, PPG Paint, TWP Stains, Sikkens Wood Finishes, Airless Sales, Service, and Rental
NCPaint1 is offline
Old 09-03-2009, 10:35 PM   #5
Metro M & L's Avatar
Trade: Painting & Flooring
graco 390 or 395. I like the graco's much better than the comparable titan.
"Yeah... It's worthy of a sig quote."
Metro M & L is offline
Old 09-03-2009, 11:18 PM   #6
finehomes's Avatar
Trade: Builder/Developer
I've got either a 395 or 495...can't remember which. I'll let it go pretty cheap!!
finehomes is offline
Old 09-03-2009, 11:37 PM   #7
Workaholic's Avatar
How cheap?
Sean
Old 09-04-2009, 07:43 AM   #8
finehomes's Avatar
$500 bucks would make me happy!
Old 09-04-2009, 02:36 PM   #9
Tuck's Avatar
Thanks for all the advice. I just bought the FT500 at Sherwin Williams. Airless, .60 gpm, 1.2 HP. Floor model, got it for $725. I feel like it was a good deal. Thanks for the help.
Tuck is offline
Old 01-22-2010, 10:19 PM   #10
TheLastDaze's Avatar
Trade: Master of None
are you meaning a double orifice tip?
NOT with latex!!
OP: Hope your new sprayer works out for you.. I'm not as versed as I used to be with sprayers but will say I was going to recommend the Titan 440 as I've had one with the same packing's its sprayed easily a couple hundred gallons, I abuse it as its just a spare rig never put spirits in it when left to sit for months on end, the prime valve is finally starting to leak adn I've had this thing for about 6 yrs..
Otherwise all we use are speeflo and graco products..
TheLastDaze is offline
Old 07-28-2010, 10:13 PM   #11
LKH's Avatar
I picked up a titan 440 multi finish and the machine keeps impressing me. If you buy one it can handle all your airless needs plus any fine finishing. The air assist feature allows you do all your HVLP spraying in half the time. For my business its been the best investment
LKH is offline
Old 09-23-2010, 02:02 PM   #12
Completespray's Avatar
Trade: Airless Paint Sprayer Store
Air Assisted Airless is the #1 choice, about 2,600 dollar range.#2 choice would be HVLP either Titan Capspray or Graco. #3 is conventional air spray, This will require a compressor but if you have one it is your least expensive option
http://www.completespray.com
For all your spray equipment & accessories!
Completespray is offline
Old 12-01-2010, 11:18 PM   #13
SasquatchPaint's Avatar
Titan 440 or Graco 390 or 395 and a fine finish tip. Turn the pressure down if you must.
Josh Schultz
http://www.sasquatchpainting.com
SasquatchPaint is offline
Old 12-19-2010, 02:23 PM   #14
CO762's Avatar
Trade: Remodel
Tho it's a done deal, Lowes has been clearancing their graco 190s for $599 less discounts.
CO762 is offline
Old 12-19-2010, 03:01 PM   #15
Can you still take it back?
Josh Schultz
The Following User Says Thank You to SasquatchPaint For This Useful Post:
CO762 (12-19-2010)
Old 12-26-2010, 06:36 PM   #16
Langpony's Avatar
Trade: Painting contractor
Get an airless paint sprayer. If you want to paint both cabinets and also do larger projects with latex paints, painting with a spray like a Graco 490 will handle all small to medium size projects.
Last edited by Tinstaafl; 12-26-2010 at 08:10 PM. Reason: Remove self-promoting link
Langpony is offline
staining / varnishing with graco sprayer meets1 Painting & Finish Work 8 03-17-2009 01:02 PM
Inexpensive sprayer for a ceiling roof-lover Painting & Finish Work 6 01-22-2009 07:41 PM
problem with magnum graco sprayer mattsak Painting & Finish Work 2 10-05-2008 03:22 AM
How to clean a clogged airless sprayer cmansmith Painting & Finish Work 9 09-10-2008 12:46 AM
Goldblatt Texture Sprayer Help JBBS Tools & Equipment 0 09-08-2008 10:59 PM
