Trade: Gen. Construction
What To Put On The Exterior Of A Timber Frame
I am having problems chooseing a product for a timber frame I am building. The home is very open, so there are a lot of points where you can see the timbers inside and out. The inside of the timbers was coated with linseed oil, the exterior nothing. The Customer what the exterior timber to look as close as possible to the inside ones. I asked the Timber folks if I could use linseed oil and he said no, he said it takes so long to dry that in climates that it gets real humid, the mold will grow in the oil, turning it black. So I buy Cabots Australian Timber oil, Then I read a thread below of a linseed oil type problem with it!
Want a natural, not shinny look. Think I'm scared of oil now. Also, the whole ceiling inside is car-siding. Sofitts are car siding. Same story, you can see them in and out. Inside was treated with Deft Satin laquer. What can I put on the outside that will kind of match? FYI: Timbers are Douglas fir, Car-siding is Pine Thanks |
Trade: siding
Re: What To Put On The Exterior Of A Timber Frame
i hear the best extierior wood finishes come from sikkens [just what i heard]
I don't think you would have any problems with boiled linseed oil, it dries. I have always added it to primer and never had a problem. And I reduce and use a chemical sprayer on my privacy fence.
#4 | |
Trade: remodel - craftsman painting - older home restoration
Re: What To Put On The Exterior Of A Timber FrameQuote:
The guys in new york that sell the infrared silent paint remover also carry a full line of linseed oil paints and are quite knowledgeable on the subject, I think you should talk to them, and they have clear linseed oil for sale also... if nothing else it may help you in your search for something else, I think the guy I talked to who knew quite a lot was named soren... you can find their number here: http://www.solventfreepaint.com/cleaned_linseed_oil.htm good luck! jordan |
Trade: Design
As Metalbender noted, I'm also skeptical about the claims the linseed oil will turn black.
In case you didn't know, linseed oil is the medium most frequently used in fine art oil paints, since the Renaissance. There are plenty of oil paintings that have survived hundreds of years without turning black, so there are some results. Also, how humid could it be in Kansas? I don't know, but it's definitely more humid here in New Orleans, where we routinely have summer days with 100% humidity. I have some wood that's been finished with boiled linseed oil, and it looks great, with no discoloration whatsoever. One thing to note is the application: rub it on, then rub it off; you want a very thin application. You can always apply multiple times. |
#6 | |
Perfection and Grace
![]() Trade: Timber Framing, Chappell Framing Square
on our timber frames we use a 50/50 mix of boiled linseed and turpentine for all of our interior beams, but never outside as mildew would be a problem for sure.
Tait Chappell Chappell Universal Square & Rule Co. www.chappellsquare.com (207)935-3720 "The Best Square in the Universe" |
whoa I didn't realize thread was 2 years old
| Pre hung exterior door composite frame | rayh78 | Carpentry | 6 | 01-27-2009 04:14 PM |
| Timber costs? | Medway Handyman | Decks & Fencing | 0 | 10-28-2008 04:53 AM |
| Timber frame arch & Iron need sources | Oregon_Rob | Carpentry | 0 | 07-27-2006 01:03 AM |
| timber frame cabin | n8sr | Carpentry | 6 | 06-01-2006 11:03 PM |
| Hybrid Timber Frame | 4powells | Framing | 3 | 04-03-2005 01:42 AM |
