What Primer For Wood Bleed Through
Old 04-14-2007, 12:41 AM   #21
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
Re: What Primer For Wood Bleed Through
Originally Posted by Woz the Painter View Post
I would cation you to not use pigmented shellac, or shellac in general on an exterior, as it is not effective in a wet environment...
I agree, it's too brittle when it dries and will crack prematurely. Unlike oil and latex which will give a little as the substrate expands and contracts.
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 04-14-2007, 05:36 AM   #22
boman47k's Avatar
Well the part about using it for exterior spot priming does throw me off a little. Seems if it could be used for spot priming, it could be used for more than spots or small areas.
boman47k is offline
Old 04-14-2007, 07:53 AM   #23
My custom title
Brushslingers's Avatar
I'd have to agree with Teetor on this one, ,although I give a strong YAY to BIN, it's not a fix for latex already on the varnished wood... it will have to be scraped back unless to want to give a 30/30 warranty....
30 feet/ 30 seconds.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 04-14-2007, 07:44 PM   #24
Traditions's Avatar
Trade: painting
Teetor, you said latex over oil is a no no. Don't people spot prime exteriors all the time with oils, then come back over with a latex?
Traditions is offline
Old 04-14-2007, 08:27 PM   #25
Teetorbilt's Avatar
Traditions, interesting that you should bring this up as I just spent the best part of today pressure washing my house due to a new problem.
In the past, the majority of the problems involved the latex reacting with the oil and producing a wrinkle finish. The minor problems involved the latex loosening in small sheets.
Today's problem involved Cover-Stain. Apparently the primer contracted and actually 'pulled' the latex off. I examined some of the chips under a microscope and the primary layer showed quite a few wood fibers well adhered. I saved a bunch of them and will be discussing this with Zinsser.
Albert Einstein
Teetorbilt is offline
Old 04-14-2007, 08:37 PM   #26
...jammin
slickshift's Avatar
Trade: Rock Disciple
Usually that's due to the oil not being dry enough
Signature Quote
slickshift is offline
Old 04-14-2007, 09:04 PM   #27
Teetorbilt's Avatar
Elaborate Slick. I know how to 'dry' oil but I expect an oil based primer to work from the can. Adding a dryer could even make things worse.
Albert Einstein
Old 04-14-2007, 09:38 PM   #28
Traditions's Avatar
Trade: painting
I'm confused teetor? Is it not ok to use oil as a primer then topcoat with latex?
Old 04-14-2007, 10:16 PM   #29
Painting Contractor
I do it all the time... I was under the impression it was the preferred method.
The NAPP
Old 04-14-2007, 10:17 PM   #30
My custom title
It's latex over oil, never oil over latex... the oil will "trap" the moisture from the water based paint beneath and rust/rot whatever is under it... the other way around is ok, but I recommend most oil lovers to get over it soon.
Benn
Old 04-14-2007, 10:17 PM   #31
...jammin
slickshift's Avatar
It's OK
It's actually necessary at times
A very common procedure
Signature Quote
Old 04-14-2007, 10:22 PM   #32
...jammin
slickshift's Avatar
Most of the times I've run into wrinkling and/or sliding off of oil-primer is the oil-primer hasn't had long enough to dry
You'd think overnight would be fine, but with humidity, fog banks, dew, and temp drops, it's not always the case
I never (well, rarely) add anything to oil-primer so I can't speak for that
Signature Quote
Old 04-14-2007, 11:24 PM   #33
boman47k's Avatar
Can moisture pushing the oil off the substrate takiing the latex with it be ruled out?
boman47k is offline
Old 04-15-2007, 10:24 AM   #34
...jammin
slickshift's Avatar
In all the cases I investigated last year the primer held fast
Signature Quote
Old 04-15-2007, 10:31 AM   #35
...jammin
slickshift's Avatar
I've used it for spot priming for decades
Sometimes the spot is a 3 foot piece of (new) replaced rake board that I'm not coming back tomorrow (when the other kind of primer dries) to paint
No worries
Signature Quote
Old 04-15-2007, 11:18 AM   #36
Painting Contractor
Originally Posted by Zinsser's TDB
Limitations – Not recommended for whole surface exterior
application or for application to floors or decks or surfaces
subject to immersion or prolonged contact with water. These
limitations are not to be construed as all-inclusive.
http://www.zinsser.com/PDF/TDB/BIN.pdf
The NAPP
Old 04-15-2007, 01:18 PM   #37
KentWhitten's Avatar
I'm not a painter by trade, but when I have had bleed through (white pine is AWFUL) Bin Zinser (sp?) is the ONLY thing I will use. Shellac based primer covers everything. And just for interior BTW, spot prime only for exterior
Salmon Falls Cabinetry
KentWhitten is offline
Old 04-15-2007, 04:16 PM   #38
Burpaz Painting's Avatar
Trade: painting
Originally Posted by ThreadKiller View Post
BIN shellac primer
this is good for bleeding in wood
Burpaz Painting is offline
Drywall primer peeling problem?? DeanV Painting & Finish Work 23 02-02-2008 11:02 AM
2 coats of primer on ceiling rather than paint? Zeebo Painting & Finish Work 20 12-25-2006 01:05 PM
Tinting primer question icfbunt Painting & Finish Work 5 12-12-2006 06:44 PM
Primer needed on metal garage door??? Zeebo Painting & Finish Work 11 08-19-2006 05:35 PM
alkyd primer or not cowtown Wallpaper 8 08-11-2006 12:46 AM
