Old 04-12-2007, 09:10 PM   #1
Traditions's Avatar
Trade: painting
what primer for wood bleed through
I have a repaint where i am spraying all the trim. the trim is previously painted old varnished wook. Looks as if HO didn't prime. There are areas where the paint is peeling badly. I primed with problock latex. Then 2 coats of proclassic latex. The yellowish brown color from the old wood is coming through. I am also painting an unpainted stair railing. I sanded and prepped well. Sprayed one coat of problock on that and it is still coming through. Should i go with the oil problock?
Traditions is offline   Reply With Quote
Old 04-12-2007, 09:13 PM   #2
Catch what you'll eat.
MattCoops's Avatar
Trade: Tile & Paint
try bullseye primer
2 coats over wood
Matt; tile contractor in Charlotte, NC
704-605-0907
Tweeting @MattCupan | read my articles
MattCoops is offline   Reply With Quote
Old 04-12-2007, 09:14 PM   #3
Teetorbilt's Avatar
Two problems. Which would you like to tackle first? Peeling or bleed through?
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 04-12-2007, 09:17 PM   #4
http://www.zinsser.com/primerapps.asp Might want to check here.
boman47k is offline   Reply With Quote
Old 04-12-2007, 09:46 PM   #5
Trade: exterior painting contractor
Cedar&Redwood? They bleed the most, and you'll most likely need a specific "oil" primer for that species!
I think that latex primers are crap to be honest with ya!
farrellpainting is offline   Reply With Quote
Old 04-12-2007, 09:59 PM   #6
As in raw wood? No kind of finish at all?
Old 04-12-2007, 10:05 PM   #7
Trade: Specialty Contractor
BIN shellac primer
ThreadKiller is offline   Reply With Quote
Old 04-12-2007, 11:09 PM   #8
...jammin
slickshift's Avatar
Trade: Rock Disciple
You could try oil
But I wouldn't mess around with it anymore
Especially not at this point
BIN It and Be Done With It
The End
Signature Quote
slickshift is offline   Reply With Quote
Old 04-13-2007, 01:08 AM   #9
If BIN or Kilz dont work try aluminum paint, we used to paint buildings that had mahogany trim that had numeruos coats of paint, yet still would bleed through everthing but aluminum...
Woz the Painter is offline   Reply With Quote
Old 04-13-2007, 01:37 AM   #10
Trade: Painter
Teetor's the man. I want to wait til he posts before saying anything.
anyway, I'd go ahead and scrape all the peeling material first. I might even wash it down. Wash or not, it should be sanded too.
Then prime with oil primer. Some areas may still bleed with one coat, so go with 2.
Joewho is offline   Reply With Quote
Old 04-13-2007, 01:39 AM   #11
Trade: Painter
Woz,
What's aluminum paint? Paint for aluminum or paint that actually has aluminum in it?
Old 04-13-2007, 05:44 AM   #12
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Traditions
BIN -1 or 2 coats should solve your issue. You could also use problock oil based as a second choice.
Sorry you did all that work and are having issues. Hope you're not losing all sorts of time and money. Good luck
Richard is offline   Reply With Quote
Old 04-13-2007, 06:25 AM   #13
Traditions's Avatar
Trade: painting
The stair case is not new wood. It is old varnished wood. not as concerned about the peeling paint. If i tore into that can of worms I could be there for a year. Homeowner knows that.
Old 04-13-2007, 04:33 PM   #14
Originally Posted by Joewho View Post
Woz,
It is basically an oil varnish with aluminum powder mixed in it. You usually see it on tanks and dust collector systems on the roofs of factories.
Old 04-13-2007, 05:54 PM   #15
Teetorbilt's Avatar
Oil is the only thing that's going to seal that mess up. Unfortunately you're going to have to remove all of the latex to do it. You've indicated that you know the right way but are looking for a quickie fix, I don't know of one. The peeling will continue even under the new paint because the original bond is breaking down. Latex over oil is a no-no and I don't care how great everybody says their primers are, they don't stick to oil or mica.
A 2-part epoxy primer will stick to mica but you have to sand with 60# and it's a mechanical bond. Epoxies were originally developed as glues.
Albert Einstein
Old 04-13-2007, 08:45 PM   #16
Workaholic's Avatar
Trade: Painting Contractor
You will need to sand wood down untill it is no longer peeling, then prime with an oil primer.
Sean
Workaholic is offline   Reply With Quote
Old 04-13-2007, 08:51 PM   #17
nick@nite
THINKPAINTING's Avatar
Bin is a spot primer for exterior work, try Cabots Problem Solver Oil.
Latex primers like Bullseye or Problock will not hold out cedar bleed.
THINKPAINTING is offline   Reply With Quote
Old 04-13-2007, 09:31 PM   #18
I took this to be all interior work. If so, Bin is an interior primer that can be used as a spot primer on the exterioir. Correct me if I am wrong.
Old 04-13-2007, 11:06 PM   #19
Trade: painter
wash everthing first with xylene .experement with what that does to the exsiting latex it might just clean it right off if it doesn't strip it anyway with some stripper . also clean your railing too . bin shelac latex HP { waterbourne clear over the H.P paint on railing } if you must but I would only use BM satin impervo oil on something like that . FYI wear a vapour mask and gloves xylene causes cancer
shakey5 is offline   Reply With Quote
Old 04-13-2007, 11:22 PM   #20
I would cation you to not use pigmented shellac, or shellac in general on an exterior, as it is not effective in a wet environment...
Drywall primer peeling problem?? DeanV Painting & Finish Work 23 02-02-2008 11:02 AM
2 coats of primer on ceiling rather than paint? Zeebo Painting & Finish Work 20 12-25-2006 01:05 PM
Tinting primer question icfbunt Painting & Finish Work 5 12-12-2006 06:44 PM
Primer needed on metal garage door??? Zeebo Painting & Finish Work 11 08-19-2006 04:35 PM
alkyd primer or not cowtown Wallpaper 8 08-10-2006 11:46 PM
