Old 02-03-2004, 09:51 PM   #1
Unregistered
Guest
Trade:
Posts: n/a
What paint for baseboard registers?
Not sure I belong in the Contractor's Chatroom being just a lowly DIYer but do I really need to use high heat paint for hot water baseboard heaters? The spray paint I've found is also suitable for painting wood stoves which seems a little extreme to me.
Any suggestions?
Thanks,
Bryan
Old 03-19-2005, 07:27 PM   #2
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
As far as I know your standard Oil based paint is rated up to about 350 degrees. Hi-Heat paints are only needed for (like you said) painting a woodburning stove and the like. A normal Oil based metal primer and oil paint should work for the amount of heat kicked out by a baseboard register.
Humble Abode is offline   Reply With Quote
Old 03-21-2005, 06:53 AM   #3
Trade:
IF the registers are just hot water base any latex paint will be fine. IF they are electric- you need hiigh heat paint. We painted all electric bases in a house at the homeowners request, and the next year I got a call that all of the paint was peeling. You asked a good question- I have been around awhile, and never knew there was a difference in heaters. I have painted all of my hot water base with the wall color which is a latex matte finish and no problem-
premierpainting is offline   Reply With Quote
why is latex paint peeling?? Zeebo Painting & Finish Work 24 05-28-2009 06:59 AM
Short Review Of Aura Paint Riverside Paint Painting & Finish Work 30 03-07-2009 08:50 PM
blistering paint GWHRsuperhero Painting & Finish Work 9 03-06-2007 08:43 PM
paint coming off the ceiling lornmastro Painting & Finish Work 6 06-02-2006 12:31 PM
