What Kind Of Finish To Put On Fir Beaded Ceiling And Clear Pine Fascia?
Old 04-20-2017, 10:48 PM   #1
Cornerstonecon's Avatar
Trade: General contractor
Rewards Points: 30
I have a customer who wants us to install a fir ceiling and redo all of his soffit and fascia with the fir and clear pine. He mentioned that he doesn't want to stain the boards, he just wants a clear pat and for it to look natural. Can anyone recommend a good product to use and also how many coats would be needed for that product. Also, I have about 3500 linear feet of board to coat, so I am also looking for suggestions on the most efficient way to apply the finish. I am open to spraying or just doing it by hand. Just interested in what everyone else suggests! Thanks in advance!
Cornerstonecon is offline
Old 04-20-2017, 10:57 PM   #2
Rewards Points: 30
Re: What Kind Of Finish To Put On Fir Beaded Ceiling And Clear Pine Fascia?
All exterior btw.... exposed to the outside elements!
Old 04-20-2017, 11:28 PM   #3
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 6,782
If non-finish type 8x2" boards are used as facia, he'd better hand select the ones to be used. Boards like that used as facia aren't usually stained due to weathering, splitting, etc. Not to mention that they don't look that beautiful clear coated.
Caslon is offline
Old 04-24-2017, 05:45 PM   #4
Stelzer Painting Inc.
stelzerpainting's Avatar
Trade: 1721
Rewards Points: 356
Not sure where you're located, but you should be able to find a few descent penetrating oil-based stains. TWP, Bakers, Armstrong Clark, even Ready Seal. Specific coat requirements predicated on exact product choice. You might caution your customer that keeping the facias a natural color will result in grey wood within a few years at most. It's the pigment in stains that act as the sacrificial barrier. No pigment = no barrier. The soffets, ya, you could get away with going natural on them.
Spray & back-brush is what I'd do.
Troy Stevens, Stelzer Painting Inc.
www.stelzerpainting.com
stelzerpainting is offline
Old 04-24-2017, 07:35 PM   #5
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,118
I too would caution that the boards will turn grey under the clear finish.
Ohio painter is offline
Minimum ceiling height for 7' garage door festerized Windows, Siding and Doors 14 06-19-2016 07:53 AM
Clear finish for fir beadboard Morning Wood Painting & Finish Work 9 08-21-2013 10:30 PM
What to do to pine beadboard when client wants a natural finish? ruskent Painting & Finish Work 3 03-23-2013 05:50 PM
Exterior patio ceiling varnish question Pipeliner542 Painting & Finish Work 4 05-20-2012 09:17 AM
Ceiling Fan , Medallion and Extension Box joejack NEC Discussion 4 05-11-2008 11:14 AM
