What Finish For Bar Top???
Old 02-11-2009, 07:05 AM   #1
Professional Remodeler
rockingjwolf's Avatar
Trade: Professional Remodeler
Hello, I am a contractor/carpenter but hope someone in this forum can help me. I am re-finishing a home bar top(mine). We bought this piece with a distressed glaze on it and under the glaze it appears to be mahogany, not the good stuff but the cheap version that they make alot of furniture out of from southeast Asia. I am going to strip it, sand it smooth and want a clear coating of some kind on it that will last. UV is not a prob. because it is inside. I have used many poly's but thought there would be something better. Any suggestions? Thanks
rockingjwolf is offline
Old 02-11-2009, 07:28 AM   #2
Frankawitz's Avatar
Rewards Points: 1,196
Re: What Finish For Bar Top???
I would use Benjamin Moore's Spar Varnish I would do shellac first do two coats of shellac, sand between each coat with 220 grit black sandpaper, then apply varnish with china hair brush, after it drys sand with 000 steel wool, in between coats, I would apply three coats of varnish.
www.frankawitz.net
Frankawitz is offline
Old 02-11-2009, 09:23 AM   #3
A bit abrasive.
WisePainter's Avatar
Rewards Points: 1,000
For something like that you could use a "bar top" product from Home Depot or Lowes. I cannot recall the name of the product, or mine sometimes, because it has been awhile.
My advice: Hire a real painter to do it.
WisePainter is offline
Old 02-11-2009, 01:50 PM   #4
Bender's Avatar
Trade: Painting Contractor
Rewards Points: 83
NO shellac.
Bender is online now
Old 02-11-2009, 02:25 PM   #5
I thought spar varnish was a good idea too, but I am not sure about what bender says about shellac. Your post says two coats and then says no shellac, can you clarify?. thanks to all of you, Jeff
Old 02-11-2009, 02:42 PM   #6
Dorman Painting's Avatar
Rewards Points: 256
I would put three coats of Zar gloss poly, no sense overthinking this thing. Sand between the first coat with a worn medium grit srubby and then the next coat with a worn fine grit scrubby. All of the suggestions are good one though, but it's not that complicated IMO. Use an ox hair brush, if not at least use a white china bristle.
Dorman Painting is offline
Old 02-11-2009, 05:47 PM   #7
painterdude's Avatar
Trade: painting contractor(semi retired)
Rewards Points: 25
if smell and drying time is a factor you can use Polycrylic..water based poly...sets up quickly and the buzz is not so bad. If this is in a basement, it's a good idea to look into. Many years ago(around 2976) I refinished a bar in a bar I worked at...at the same time me and the owner wanted to get ride of a case of Schlitz that wasn't selling...I did the bar and burried him. 6 hours of my life I'll never get back. As soon as I hit the fresh air I was fine, but have no recollection of the work and beer. pd
painterdude is offline
Old 02-11-2009, 06:32 PM   #8
Forry's Avatar
Trade: General Contractor, Remodeler
Rewards Points: 526
I've used this. Around here it's called "pour-on". Two part epoxy stuff. You wouldn't need to sand if you didn't want to. It goes on thick.
now i am scared for my future
i've got all ten
smashed a lot of them stupidly before
-john5mt
Forry is offline
Old 02-11-2009, 09:01 PM   #9
Paintpimp's Avatar
Trade: Paint
Rewards Points: 75
The product to use is by the company Envirotex. The smaller kits are called Pour on finish and the professional end is called Crystal. A furniture maker that supplies furniture in the Cabela's catalogs uses the Crystal. Awesome looking, tricky to use. I believe their website gives hints on how to use it. Practice first.
Paintpimp is offline
Old 02-11-2009, 09:39 PM   #10
New and Remodel Carpentry
cooks's Avatar
Trade: General Contractor/Remodelor
Rewards Points: 75
http://www.amazon.com/dp/B000M2SWNS/...0&linkCode=asn Here is what you are looking for, home depot sells it. I have done this on bar tops before if done right looks like a sheet of glass. If i can get a picture i will post it up.
cooks is offline
Old 02-12-2009, 12:37 AM   #11
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,082
Ok, so what is the trick to the epoxy?
sparehair is offline
Old 02-12-2009, 06:18 AM   #12
A bit abrasive.
Epoxy has a sweet spot that you gotta hit just right or you are in trouble...real quick.
Practice is the only trick to epoxy, On the job or in your own home.
I prefer on the job because that is how I roll.
Old 02-12-2009, 08:41 AM   #13
Frankawitz's Avatar
As for Benders post I don't know what he is talking about the Shellac gives the wood depth in the look, and it's been used on wood for hundreds of years, Shellac gives wood that Rich look to it, As for water base products think about it, you will need to refinish it every 4 years, If you want it to last for years do the Varnish and Shellac. I have restored allot of woodwork over the past 29 years, this is the way we always do our stained woodwork. Good luck, I guess Faster is Better, instead of taking your time.
www.frankawitz.net
Old 02-17-2009, 10:26 AM   #14
I finished this job and all of you were a big help. I ended up doing 5 coats of spar varnish, sanding lightly between and 0000 steelwool before last coat. It came out great, smell almost killed me but I am not a big fan of water based finishes though I prob. could have saved a few brain cells, oh well...
Old 02-17-2009, 06:25 PM   #15
A bit abrasive.
Nice!
Old 02-18-2009, 09:18 PM   #16
www.DPAP.org
BAForese's Avatar
Trade: decorative painting
Ever tried Ceramathane by Graham Paints as a sealer? I heard about it recently and I'm going to try it on a commercial bar top in a few weeks. It gets rave reviews from others that I know. Any opinions on that product?
BAForese is offline
Old 02-18-2009, 09:32 PM   #17
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
I'm no coating specialist, but every bar I build isnt finished until its covered with EMPTIES
loneframer is offline
Old 02-19-2009, 08:31 AM   #18
A bit abrasive.
badum.dum.tsss!
Old 11-03-2010, 02:40 PM   #19
Huegymbicil's Avatar
Trade: Cabinet maker
Use a mixture of linseed oil, spar varnish, and thinner for the first coat. Poor on liberally and rub into wood with a small piece of burlap, then wipe off access after it's soaked in for a while. Do 2 coats, wet sanding in between with 320 wet-dry paper.
Afterward do another 2-3 coats with just spar varnish, thinned down slightly. Apply this with a brush - wipe off access only if you want a thin coat. Otherwise, if you want a thick coat just let dry.
Shellac is a good idea for 1st coat, but this method is easier and has the same affect. Don't use water base unless you want it to wear out sooner.
Huegymbicil is offline
Old 11-04-2010, 06:23 AM   #20
hoz49's Avatar
Trade: Painting and allied trades
Rewards Points: 25
Forget varnish, shellac, poly sealants etc. For a hard durable finish use epoxy.
Here's the goods. Sorry I can't post urls yet but google US Composites Epoxy Resin
scroll down to Kleer Koat Table Top.
Make sure all old coatings/wax have been removed and wipe down with alcohol or acetone prior to application.
hoz49 is offline
EXT, finish choices genecarp Painting & Finish Work 19 12-08-2008 03:47 AM
Dirt in Finish banctecbobn Flooring 18 09-19-2008 05:19 PM
Clear finish over 3 dimensional objects jbusheyvt Specialty Coatings 1 08-22-2008 01:46 PM
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 03:41 PM
Stripping old deck finish joedonuts Painting & Finish Work 26 06-09-2007 10:34 PM
