What Do YOU Do To Remove Exterior Oil To Bare Wood?
Old 08-02-2006, 08:58 AM   #1
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Im looking for anything now, my last post wasnt too successful-
Im just wondering what you personally would do...I'm a nice guy and a damn good painter- just looking for input from some pro's
ps- am I worthy enough to get some responses from some of you top answerers, you know who you are
Richard is offline
Old 08-02-2006, 09:02 AM   #2
My custom title
Brushslingers's Avatar
Re: What Do YOU Do To Remove Exterior Oil To Bare Wood?
How old is the house? If it's a historic i'd hire an outside chemical stripping company to give a bid and do the work. If it's a newer style house and has Georgia Pacific siding on it, i'd tell the HO to hire a siding crew and replace it all with Hardie.
Give me more info
Benn
Originally Posted by Brian
Brushslingers is offline
Old 08-02-2006, 12:16 PM   #3
Richard's Avatar
ok...the house is historic, I'm only doing 1 part of 1 side of the house...it's about 300 square. They have had continuous problems with this side peeling and cracking, so I thought I would bring it to bare wood, put a good oil primer on it and 2 coat it with PB. I have done a lot of sanding with a disc sander and can do it without f-ing it up (sorry). I just wanted to see what you all would do. Do some of you burn still? They actually did replace part of the house with Hardy at one point. This section is the East side and gets nailed with sun. I am kinda taking a chance even painting it, due to the fact that this prob. keeps happening.
Richard is offline
Old 08-02-2006, 01:25 PM   #4
My custom title
Test the wood, if it's historic.. ie 100+ years, they used kerosine to prime wood, test it for moisture or you will always have that problem. Other than that, I don't suggest burning, if caught you will be shot on site. If it's on the sun side and it's bubbling within 4 years, theres something on the wood so your right in stripping to the bare... just gotta figure out what it is. Really depends on HOW historic it is, gimme a build date.. type of wood, how many coats. I did lots of these in Atlanta, Charlotte and Dover. If it's say... 80 years old you could most likely use a lead abatement primer to go over the paint... if its in the lines of 100, you'll have to find a chemical stripping company or buy alot of gear to take care of it. Touchy when working with Historic homes. Got a picture?
Benn
Old 08-02-2006, 01:49 PM   #5
Jon F's Avatar
Trade: Log Home Services
....obviously since I am the only one that answered your previous question, I'd not be consider a "top answerer" I suggest you give another look at my info though, and do about an hour of research online/google about this product/ similar products and you'll find out it is a pretty good solution. They have products that are used for safely (dont quote me) stripping lead paints, etc. as well.
Jon F is offline
Old 08-02-2006, 05:06 PM   #6
...jammin
slickshift's Avatar
Trade: Rock Disciple
What town and how historic?
Is it registered?
I ask because there are some specific issues with certain historical districts in my old stomping grounds in CT
Like acceptable procedures, colors, etc...
If you don't want to post up the town, PM me
On the actual problem, is it peeling from the outside in, or the inside out?
Is it on the shore?
Signature Quote
slickshift is offline
Old 08-02-2006, 08:05 PM   #7
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
I don't know if I rank up there in the Top Posters like slickshift, but will offer this:
Have you considered the Paint Shaver Pro?
ProWallGuy is offline
Old 08-02-2006, 09:17 PM   #8
Painting Contractor
JMGP's Avatar
Ready Strip - Pro....Bio Friendly.. Covers opprox 75 sq. per gal...
Brush on... leave over nite...
Scrape off (with ease) in the morning)...
Light rinse... let dry... light sanding... apply 30% diluted (thinned)oil primer... let dry.... sand... apply full primer... let dry... apply 2/coats acrylic paint....
JMGP is offline
Old 08-02-2006, 09:19 PM   #9
...jammin
slickshift's Avatar
I have been dying to try this on one of these paint failures on shake shingles I've been running across up here
I'd like to see how it handles these shingles
I don't know if I rank up there in the Top Posters like slickshift...
Don't worry, you're pretty rank yourself
Signature Quote
Old 08-02-2006, 09:23 PM   #10
My custom title
Ok you got me, the what? Got a website?
Benn
Old 08-02-2006, 10:00 PM   #11
...jammin
slickshift's Avatar
http://www.paintshaver.com/
Signature Quote
Old 08-02-2006, 10:25 PM   #12
ProWallGuy's Avatar
Eureka!
Old 08-02-2006, 11:02 PM   #13
Teetorbilt's Avatar
If you're smart, you'll have one made.
Most are based on a cheap, small offset grinder ($60, retail). The head is the key and most any machine shop should be able to kick one out for under $200 AND they will use common cutters which will cost much less than propritory cutters.
Albert Einstein
Teetorbilt is offline
Old 09-24-2006, 07:59 PM   #14
Richard's Avatar
ahhh...disc sander works again....
thanks all for the answers, but I just used the old 5" disc.....came out sweet, just gotta throw the 2nd coat of finish on this week
Richard is offline
Old 09-24-2006, 09:09 PM   #15
...jammin
slickshift's Avatar
Tried and true
That works
Signature Quote
Old 09-24-2006, 09:15 PM   #16
Terrence's Avatar
Trade: painting and carpentry
Hey Teetor
I've been looking at that unit and drooling, but all the while wondering if it was a grinder at heart. Do you really think a machinist could make it work properly-- Like go to the right depth and be adjustable and all that?
How did you come up with $200? Have you had something like this done?
Hope this isn't a stupid question...
Terrence is offline
New kind of Pressure Treated wood karma_carpentry Carpentry 23 08-21-2008 09:06 AM
Pressure Treated Wood rjordan392 Carpentry 4 05-28-2007 02:23 PM
Wood people I need your help Floorwizard Flooring 11 05-18-2006 09:07 AM
Really Dark Wood...Primer/Application Q slickshift Painting & Finish Work 13 04-28-2006 04:47 PM
Paint peeling curling down to the bare wood! CurbAppeal NC Painting & Finish Work 2 03-17-2005 11:31 AM
