Waterborne Cabinet Paint Questions
Old 12-25-2017, 09:43 PM   #21
tjbnwi's Avatar
Rewards Points: 3,634
Re: Waterborne Cabinet Paint Questions
Originally Posted by zukinut View Post
I've read the caulk/no caulk threads, but what do y'all do personally? Sometimes raised panels could use some caulk, and sometimes a wall is way out in different planes and getting an exact fit for is almost impossible due to not being able to put it in and it needs a small caulk joint to the wall.
I caulk panels on pigmented finishes. SW Sher-Max.
tjbnwi is offline
Old 12-25-2017, 10:02 PM   #22
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 866
I used the airless on my first job. It's possible yes, but you get a lot more over spray that way. They have the Fine Finish Low Pressure (FFLP) tips now which should do better than a regular FF tip but I haven't used my airless since the first job.
Xtrememtnbiker is offline
Old 12-26-2017, 06:12 AM   #23
rrk's Avatar
Rewards Points: 2,088
Originally Posted by tjbnwi View Post
Not sure where you're located in NJ.here is one of the stores that will handle and custom blend it.
https://www.sherwin-williams.com/sto...ington/nj/4350
The store I deal with will ship it to you FedEX if necessary.
I have gone there before which happens to be 1 1/2 hrs from my house only to find out he did not have any but could order 5-5s. Which would be way more than I need and 2 weeks to get. As usual with SW here they will tell you one thing and do another.
rrk is offline
Old 12-26-2017, 07:37 AM   #24
tjbnwi's Avatar
In that case, I would not be using the product either.
tjbnwi is offline
rrk (12-26-2017)
Old 12-26-2017, 09:04 AM   #25
Railman's Avatar
Trade: Railing
Rewards Points: 459
We have used their products (with several name changes) for about 25 years. We currently buy well over 1,000 gallons/year of stains, sealers, top coats, white primers, & white top coats. Yes, we have looked at a lot of alternatives over the years.
I'd start here, to get info on how to proceed with spray equipment . They will ship small quantities pretty much anywhere, weather permitting
(freeze factor).
https://aquacoat.com/blogs/news
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
zukinut (12-26-2017)
Old 12-26-2017, 11:07 AM   #26
zukinut's Avatar
Trade: electrician by trade, general contractor, cabinet maker
Rewards Points: 90
It's looking less and less likely that I'm gonna be able to get the kem aqua here. The girl at my local sw is looking into it, but it's not looking good.
I'll check out the link you provided railman
Edit: girl at Sherwin Williams came thru. I can get it in singles and they can tint it for me. Now to decide on the sprayer to buy.
Will
zukinut is offline
The Following User Says Thank You to zukinut For This Useful Post:
Xtrememtnbiker (12-26-2017)
Old 12-28-2017, 10:32 AM   #27
Railman's Avatar
Trade: Railing
Rewards Points: 459
any progress?
Railman is offline
Old 12-28-2017, 01:20 PM   #28
zukinut's Avatar
Rewards Points: 90
I'm gonna give the kem away plus a go. I've probably got 2 weeks of work till I'm to the point of using it.
What primer do y'all use when going from an oil to a waterbourne? Even when properly sanded I've had issues with latex problock sticking.
Thanks again for all the help, it's greatly appreciated.
Will
zukinut is offline
Old 12-28-2017, 02:12 PM   #29
tjbnwi's Avatar
Will
Wash the surface with Kurd Kutter, scuff sand with 220, wash again,blow out seams, caulk if going over with pigmented, wash agian, KA+ Surfacer, sand, address any issues, Surfacer, sand, top coat.
Easy peeze
tjbnwi is offline
Old 12-28-2017, 03:10 PM   #30
zukinut's Avatar
Rewards Points: 90
Ok, cool, sounds easy peezee just like you said.
Same process for the cabinet that has latex over the oil, correct?
One last question and I won't bother y'all anymore, what primer do you like for going over oil if using the water alkyd pc? I have something I wanna try the water alkyd on and sw comp'd me a gallon to try.
Thanks again, I was worried about this upcoming project and now I feel very confident.
Will
zukinut is offline
Old 12-28-2017, 04:43 PM   #31
tjbnwi's Avatar
Styx.
tjbnwi is offline
Old 12-28-2017, 04:52 PM   #32
rrk's Avatar
Easy peeze
You really do not realize how much crap is on the doors until you wash them with Krud Kutter and look at the rag or paper towel.
rrk is offline
Old 12-28-2017, 06:55 PM   #33
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,632
Styx.
Tommy Shaw was one of my favorites, but for primer I would use Stix. It sticks, and sands nicely.
Home Designer Series Software
B.Johnson is offline
Old 12-28-2017, 08:02 PM   #34
zukinut's Avatar
Rewards Points: 90
I just painted some interior doors this week that looked almost new with a good krud kutter wash and rinse.
Will
zukinut is offline
Old 12-28-2017, 09:05 PM   #35
tjbnwi's Avatar
Saw them when they were Trade Winds. Used to listen to them practicing in James Young's parents basement when they were TW 4.
Ran into DeYoung in early 80's I was fueling the Pantera at Gas City in Frankfort IL, he pulled up in a Ferrari. We talked about the cars.
Bet you didn't expect this......
You are correct about the Stix.
tjbnwi is offline
Old 01-02-2018, 09:04 AM   #36
zukinut's Avatar
Rewards Points: 90
What do y'all think about the Ben moore advance? I naturally can't get the deals I can get on sw proclassic but I can now readily get the advance. I had no clue my favorite lumber yard had a paint dept. they said they hear that a lot. I think I would fix the issue with a sign or something, but alas
Will
zukinut is offline
Old 01-02-2018, 10:17 AM   #37
tjbnwi's Avatar
Will
Great, if you have 30 days to wait for it to fully coalesce.
tjbnwi is offline
zukinut (01-02-2018)
Old 01-02-2018, 01:36 PM   #38
rrk's Avatar
I use Advance with no issues, just needs a few days left alone
rrk is offline
Old 01-02-2018, 07:33 PM   #39
zukinut's Avatar
Rewards Points: 90
How long does the acrylic alkyd pc need to be hard enough for service? Gonna try some tommorow.
Will
zukinut is offline
Old 01-02-2018, 07:51 PM   #40
tjbnwi's Avatar
I wait 48 hours.
tjbnwi is offline
Painting Siding FrankSmith Painting & Finish Work 40 05-21-2013 08:40 PM
Porch/Deck Hybrid Design Questions... Spencer Decks & Fencing 7 04-27-2013 06:38 PM
Kitchen Cabinet Build CITY DECKS INC Finish Carpentry 70 01-03-2013 06:51 PM
How to paint prefinished stained cabinet white????? Spencer Painting & Finish Work 6 01-06-2010 09:34 PM
